Question about Garden
Craftsman model 917.28852 seat removal - Garden
How do you get the battery out of a craftsman rear engine mower? what all do you have to take off? it's a model 247.25000 thirty inch cut.
Accessing the battery in this model is different from most mowers. To access the batter you have to remove the seat first, then remove the knobs on the levers that go through the fender, next, remove the two screws in the rear cover.. After you have theses removed, take the screws out that secure the fender to the mower. it should have 4 to 6 screws located under where the seat would be. then lift the fender off the mower. the battery is on the left side. just remove the cables and the battery hold down. then lift the battery out of the mower. to install the new battery just reverse these steps.
Jul 07, 2017 | Craftsman Garden
What size is for a craftsman LT3000 blade belt 42 in deck?
June, google search your make, model #, deck belt.
LT3000 is not a model # , The model and serial number of a Craftsman riding mower is located on the frame under the seat, or on the underside of the seat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 20, 2016 | Craftsman Garden
Craftsman 944601090 seat safety switch problems
You should only need two of the three wires remaining. I also can't find your model number anywhere. Did you post the model number correctly?
Jul 15, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Managemylife com
Best guess look at new seat for bolt holes there are no pictures
that I can find.
Apr 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My tractor dies randomly. it just bogs out, and dies. it might start right up or it might take awhile. I replaced the coil, fuel filter and made sure the carb was clean.
Craftsman 17.5 hp 42 in. Deck Lawn Tractor model 917.272670 ohv, 0 compression, removed head found valve seat insert out/on angle, valve unable to close. Can this be re-seated, adjusteded or is new head required? Rich
Aug 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman riding mower model 917.273756. when
Sounds like one of your safeties are bad. Probably the seat switch (operator presence switch) under the seat. Pull the seat up and look at your switch. If you have meter then check for continuity when the switch is made.
Report back.
Mike
Oct 24, 2009 | Craftsman Garden
Starting Craftsman model 917.270430 riding mower.
There's a safety shut-off switch below the seat, so when you're seated the switch is engaged. If you were to fall off the mower, the engine and Blades stop (safety feature).
Check the switch to see if it's operational.
Beyond that, mower may need a tune up or servicing, if it is not starting.
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 18.5 briggs/str 42''
flop the seat forward, push the connector firmly onto the seat switch [in the middle of the seat underside], should solve your problem, or the switch could be bad, but not likely unless you're 300lbs
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
