Question about HP DeskJet 5550 InkJet Printer
Can't print Trying to print and I my pc is not communicating with my printer because the printer isn't doing anything.
    President:
  • 317 Answers
Assuming you have Windows XP, download and install this driver and see if it fixes your problem. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-7095-2&lc=en&cc=us&dlc=en&product=71896&os=228&lang=en
Posted on Aug 27, 2007
SOURCE:
Should "cleaning the print nozzles" do anything with the color cartridge?
First, make sure the cartridge isn't dry. You may have to get into the Printer Preferences and check to see if the software hasn't been changed to 'black only'.
Feb 08, 2012 | Lexmark X2690 All-In-One InkJet Printer
My HP Photosmart C4280 stopped printing documents.
it stopped printing and saysthat something is wrong some spooler error
May 03, 2010 | HP Photosmart C4280 All-in-One InkJet...
I just purchased a C540, color laser printer. HOWEVER, in setting the printer up, and trying to print anything, the printer won?t print. Nada. Seems as if there is no communication. Everything is plugged...
u have to installed driver first in your PC then after cheak your printer installed correctly go in control pennal open printer option see there there was showing your printer if u have installed correctly then after right click on it then set is as a default printer then try to print
Nov 15, 2009 | Computers & Internet
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
PhotosmartC6180 printer is not communicating with PC.
did it detect your printer while installing? check your device manager see if USB device has any yellow excalamation mark right click and unistall it then restart your pc. it will detect your printer then you can print anything you want
Mar 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lexmark 2600 printing problem
You might try deleting the printer from the 'Printers and faxes' folder in the Control Panel, reboot with the printer connected and turned on. Win should 'find' it again and reinstall the driver.
Dec 22, 2008 | Lexmark X2600 InkJet Printer
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
The printer will not print anything except the test or allignment sheet.
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
thanks.
Oct 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer don?t print
Hi, the problem can be related to any of a number of things. First of all make sure that there isn?t any extraordinary LED blinking. Every LED has a troubleshoot in the manual(which you can download here on Fixya). If there?s no blinking going on check for the following: The power supply to the printer, along with the line(cable and socket). That the ink cartridges fit well. You have paper in the tray, and there?s none stuck inside. The printer cover is well shut. All parts are well connected(such as the paper tray) If everything seems to be in order try connecting it to another computer? maybe the USB connection isn?t a 100 percent, and the communication between computer and printer is at fault, or there?s some software problems, or anything that?s computer related. Could also be router or print server problems if you are using either one. Check out the troubleshoot pages for your router here in Fixya, they contain reference to that on some routers.
Feb 21, 2006 | HP DeskJet 845c Printer
HP DeskJet 5550 InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
