Heating & Cooling Logo
Anonymous Posted on Jul 10, 2013
I have an gree air condition . split out door power automaticly turn ofurn
5 Related Answers
Donni Steen
  • 687 Answers
  • Posted on Mar 31, 2009
SOURCE: LG S36AHP-UD7 Split Air Con. won't turn on.
Generally when an ac trips the main breaker and the breaker its self isn't bad, the compressor is going bad or is bad. To check you will need to do an ohms test on the compressor. If you get a reading of less than infinite, then the compressor is bad. You will need to test every lead going to the compressor which is usually 3 unless you have a crank house heater installed but they are not typical on a small unit. If the compressor has gone bad it is possible the it took the board out as well.
Anonymous
  • 5 Answers
  • Posted on Jan 18, 2010
SOURCE: Gree air conditioning unit turns itself off and
i had this problem it was freezing up outside it was only a short pipe run so it was over gassed i took some out and it was fine
Anonymous
  • 1751 Answers
  • Posted on Jan 17, 2011
SOURCE: i bought gree air condition but is having short
Hi wait a moment pls your request is been proceeding..
Anonymous
  • 332 Answers
  • Posted on Feb 20, 2013
SOURCE: GoldAir Airconditioner F9 Error
Is the power supplie dedicated to just the ac because it should be check power needs in manual
AC PART
  • 8 Answers
  • Posted on Jul 05, 2013
SOURCE: My new gree air conditioner split system has an E1 error
http://www.aliexpress.com/item/2013-Residential-Air-Conditioner-Commercial-Air-Conditioner-Spare-Part-GREE-Air-Conditioner-Remote-Control-Y512/893088745.html
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
How to reset gree split indoor unit by using remote controler
turn power off and back on. you may end up having to cut power to the machine.
Why will the unit keep heating when the temp is above the set point?
Last month, I had this exact same issue where my temperature was not matching the set point on my heating system. I called an HVAC specialist and had it looked at. The issue turned out to be due to the fact that I always kept the heater on, instead of just on auto. These types of malfunctions seem to happen when people continually blast their heat or AC. Kelowna Heating Air Conditioning Services
My gree mini split 2400 heat pump air conditioner does not turn off at the set temperture when cooling
I am not sure about your specific model. However most A/C units I have worked with have a fan switch. The switch allows you to choose to have the fan on all the time or only when the unit is cooling. Some of these switches are behind the front panel, behind the panel or out in the open it should be close to the other controls. Hope this was helpful.
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
13helpful
4answers
My greewall mounted has a e1 prblem.how van ifixor what is the problem
11helpful
4answers
Gree air conditioning unit turns itself off and has an error code of HI dont know what the error codes are
Top Heating & Cooling Experts
Paul Carew
john h
