Question about Video Game Consoles & Games
Detectomat 3004 I am having an allarm on the display of fire control panel 3004, the alarm is earth fault. What dose this mean an how I have to fix?
  • 5 Answers
SOURCE: Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Posted on Jul 18, 2007
faxman789
  • 297 Answers
SOURCE: Control panel displays backwards
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=236,E=0000000001178571592,K=3886,Sxi=16,Case=obj(3690)
Posted on Jan 16, 2009
  • 54 Answers
SOURCE: it showes me on the xls60e fire panel ardesseble
An "earth fault" or ground fault is a condition where one of your circuits is grounded or shorted to earth. While all fire alarm systems are normally grounded for circuit board overload protection and personal safety issues, all circuits (bell circuit, smoke detector/heat detector/pull station circuits) should be free of earth grounds. I would suggest if you are not knowledgeable enough to troubleshoot your system you should contact a security/fire alarm installation company to fix the problem. If this is not a viable solution and you want to attempt this on your own try removing each circuit from the panel one at a time. While this will certainly cause additional system troubles, when you remove the circuit causing the earth fault the condition will disappear. You will then need to check all wiring, spice points and devices on that circuit to determine the faulted location.
Posted on Feb 03, 2010
paulc118
  • 15 Answers
SOURCE: fault 23 is displayed on the control panel after
F23 means that the required pyrolitic temperature was not reached during the self-clean cycle. If the other half of the oven does not do this, then it could be a problem with a door lock switch or one of the overtemp sensors.
Posted on Feb 27, 2010
Testimonial: "Thanks - I am sure there is a temperature problem as this oven is cooking much slower all round."
espressonist
  • 1711 Answers
SOURCE: Identify (an remedy) fault. Alarm sounding and
Fault Alarms
If the electronic controller detects a fault from which it is unable to recover an alarm will sound.
When the fresh food compartment door is opened a fault code (specific pattern of lights) will
flash red and green on the Control panel to alert you to the fault. The audible alarm will stop
when any button is pressed but the lights will remain flashing.
If such a fault occurs, call your Fisher & Paykel Appliances Authorised Service Center immediately;
the fault code will help the service person find and remedy the cause of failure.
Posted on Sep 26, 2010
How to fix e90 code? is there a fuse or reset button?
Question
What does code E90 mean? What should I do if code E90 appears on my air bubble spa control panel?
Answer
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Apr 04, 2016 | Intex Pool & Spa
Sensotec 7000e fire alarm
The power supply is bad, which will cause the other troubles. It will need to be replaced by a qualified and certified life safety technician.
Sep 08, 2014 | Home
The sensor Honeywell TC807A 1036 (Smoke Detector), is compatible with a NFS-320 Fire Alarm Control Panel?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
Oct 23, 2012 | Honeywell Tc807a1036 Smoke Fire Detector...
I have a locked rotor fault message.
I had this fault show this morning. Very alarming, as we have a typhoon coming theough tomorrow!
Turned out to be an easy fix. When I hit start the solenoid engaged but nothing moved. Then I saw the fault message and thought "Large $$$$!"
It was just a bad 12 Volt battery, and when it couldn't crank it threw the fault code. I replaced the battery, pulled the 3 fuses on the control panel (mine is the 20 Kw model), and the codes cleared, and she fired right up.
The advice here and on a couple other sites about powering down the panel to clear fault codes saved me a lot of time, money and aggravaion, not to mention a freezer full of food (knowing the Guam Power Authority, and knowing typhoons, the power WILL go down tomorrow.
Jul 27, 2012 | Kohler 14resa 14kw Home Emergency Backup...
Fire alarm panel showing problem on 2 zones
Your smoke detectors, heat sensors or fire pull stations (depends on what is installed in your system) are located on your 4 zones. The wiring that connects these sensors to your fire control panel is supervised by an end-of-line resistor. Starting at the panel all wiring on that zone is daisy chained between each detector with the resistor being placed at the last detector. The panel looks for this resistance value at all times. If one of your detectors goes into alarm this creates a short. This is how the system recognizes an alarm state. Conversely, if there is break in the wiring the system fails to see any resistance and the panel will indicate a problem or trouble condition. The most likely cause of your 2 problems is either broken or cut wiring, ie; the system no longer sees the end-of-line resistance. If you are handy and have access to a multimeter you can measure resistance along the zone loop by disconnecting the zone wires from the panel and measuring wire resistance from each detector to the last one. Most Firelite systems use a 4.7k ohm resistor so you should see this at the zone wiring from the panel. If you don't, try removing a detector somewhere in the middle of the circuit and try again. Once you find a detector with that resistance your problem lies between that detector and the panel. It is just a matter of isolating the problem by measuring the zone resistance along different points of the zone wiring. If you are not comfortable doing this by yourself then I would suggest getting either an electrician or fire alarm tech to track down the problem. Hope this helps.
Dec 29, 2010 | FireLite 4 Zone Conventional Fire Alarm...
Hi, i'm using the Caddx NX4V2, the fire light flashes rapidly and no keys are working to stop it, i did read a manual that says the rapid flashing fire led means that there are problems ... how do i pin...
If you know the 'go' code ( default 9713 ), you can press *+90 to see the event log, which you scroll through with the arrow keys on the keypad (alpha keypads only). If that is not available, you will need to have a certified alarm installer come and check your system for faults.
Dec 13, 2010 | GE Iti Caddx Nx4 Control Panel 48 Zone...
What does juniper: true alarm true value mean?
Call your fire panel representative. I have seen this problem and consulted with the factory. It has something to do with the program loaded into your system.
Mar 01, 2010 | Simplex Computers & Internet
It showes me on the xls60e fire panel ardesseble
Feb 03, 2010 | Honeywell Home Security
Antivirus zone alarm
hi pc it could be one of two things your zone allarm may be set up to check for new version of zone allarm and if it you want the lattest version then it's safe to accept the pop up, or it may simply be an undate for zone allarm also safe, provided it comming from zoneallarm your ok.
Oct 08, 2008 | Computers & Internet
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
