Question about Canon Office Equipment & Supplies
Where is the polling button on a cannon F147400
Which is the button I can press as our fax machine has stopped giving us receipts as I dont know whether faxes have been sent now! Somebody has been tampering
DJYar
  • 41 Answers
SOURCE: wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Posted on Aug 23, 2007
SOURCE: fax receipt from Canon Super G3 Fax-L220
Insert paper and press Stop.
Posted on Aug 15, 2008
leroyal
  • 2120 Answers
SOURCE: fax will not send
Does the receiving or sending party have a DSL phone line?
Posted on Sep 01, 2008
  • 320 Answers
SOURCE: Intellifax 2800 fax machine
my suggestion would be to down the manual from brother.com
Posted on Jan 20, 2009
iservice
  • 318 Answers
SOURCE: Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Posted on Sep 11, 2009
I need to reprint the last inoming fax. HELP!!!
Printing a Fax in Memory If you have Fax Storage ON for remote retrieval, you can still print a fax in the memory when you are at your machine: 1 Press Menu/Set, 8, 4. 2 Press Fax Start. 3 Press Stop/Exit. (See Turning On Fax Storage, page R-2.) Polling For details about the Polling feature, call our Brother fax-back system 1-800-521-2846 (in USA), 1-800-681-9838 (in Canada) and request at the Index. (See Features That Are Not in the Manual, page 6-6 for details.) Polling is the process of retrieving faxes from another fax machine. You can use your fax machine to "poll" other machines, or you can have someone poll your machine. All parties involved in polling need to set up their fax machines to accommodate polling. When someone polls your machine to receive a fax, they pay for the call; if you poll someone's fax machine to receive a fax, you pay for the call. (See Canceling a Scheduled Job, page 6-5.) Some fax machines do not respond to the Polling feature.
Jun 24, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I am getting error 244 when receiving a fax.
errors 243 and 244. Taken from HP.
The user of the remote machine has pressed that machine's Stop key causing the session to be prematurely terminated. Alternatively: the remote fax machine determined there was a feature incompatibility between the two machines and has terminated the session. An example would be when the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solution:
1. Confirm the remote user is not inadvertently attempting to poll transmit from the local machine, instead of transmitting to the local machine. This mode of operation must be specially configured on the local machine. If poll transmission from the local machine is the desired mode of operation, confirm the local machine has been configured for this operation.
2. Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed
Sep 20, 2010 | HP 910 Plain Paper Inkjet Fax
Cannon laser fax 1060 P "check paper size"
Hi Margaret
Ok,the problem normaly with this model is in the feeding of the paper.For some or other reason the paper is moving to slow threw the machine and then the machine detect it as a longer size paper.
  • Clean the rollers that pick the paper up and clean also the sepatation rubbers under neath the paper pick up rollers.This rubbers is called the separation pads.
  • To clean this rollers,remove the cartridge and you will see the feed roller at the back.
I think what happened with the move the machine might collected dust and now the rollers are slipping.
Thanks for you support
Dec 29, 2009 | Canon L220 Plain Paper Laser Fax
How do I stop my Canon Faxphone from redialing when I mistakenly enter a wrong number and how do I stop my fax from giving me sent receipts
While the fax open the line and dail you can press the stop button,it will display cansel tx you select yes
Nov 19, 2009 | Canon FAXPHONE L80 Laser
How to cancel a transmission
Pages 110 & 111 in users manual. During a direct transmission, press stop. For memory transmission, press job cancel, then select one of the 5 choices to cancel. 1.Transmit 2.Receive 3.Polling 4.Polling Reserve 5.Job Number Use the number keys to select the choice. Press Enter to cancel the selected job. To confirm deletion press1.
Oct 06, 2009 | Toshiba DP-85F Fax
How do you get rid off polling on the machine. I am trying to fax and when I hit the send button the machine is asking "do you want to poll" I hit "no" and it is not responding!!!!
Be sure you're putting in the original you want to fax BEFORE you dial the #....if you are, be sure the fax knows that you have put the original in...it should say somethng like 'dial the #' or something like that
Aug 26, 2009 | Office Equipment & Supplies
Our Brother intellifax 2800 won't receive some faxes
Not entirely positive but it looks like you need to enable "polling" on your machine. I think it's a way to ensure they don't send out personal medical info to a wrong number by mistake. If polling is enabled, they've already determined that your machine is expecting a call from theirs.
To enable polling on your machine:
  1. Press Menu/Set 217
  2. Use Up/down arrow to turn on polling
  3. Enter the fax number you're polling
  4. Press Fax Start to dial that number
  5. Press Menu/Set
I hope this works for you. All the best!
Greg
Jun 17, 2009 | Brother IntelliFAX 2800 Laser Fax
Clearing memory on fax machine
while pressing memory , press also Minus -- or Delete
Nov 07, 2007 | Office Equipment & Supplies
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
43 people viewed this question
old marine
old marine
