Question about KitchenAid KUDE60HXSS Builtin Dishwasher
Missing Drain Hose
Purchased this dishwasher as a floor model. Went to install tonight and realized there was no drain hose included. Bought a simple one from Lowe's and it did not work. Any suggestions for type/brand of hose I should get to alleviate this?
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
dmftrucker
  • 1922 Answers
SOURCE: What is the part # for a drain hose on a
AP4399659 Whirlpool part number
wpcustomer
  • 345 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: I just installed my kitchen
    Hi, my name is Audrey. I am a KitchenAid employee and thought the following link might help address the draining issue you're having with your dishwasher:
    http://kitchenaid.custhelp.com/app/answers/detail/a_id/84/kw/not%20draining/session/L3RpbWUvMTI4ODEwNzU5Mi9zaWQvOVEyalRzZGs%3D
    If I may be of further assistance to you, you may send me an email through our customer service address,
    KitchenAid_CustomerExperience@KitchenAid.com
    and type 'Attention: Audrey' in the subject line. Please include your full name and model/serial number, and I would be happy to try to help resolve the situation with your dishwasher.
    Posted on Oct 26, 2010
    KevinWhite
    • 1902 Answers
    SOURCE: KA model KUDI021R SS#
    Hello & Welcome to FixYa
    Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
    High temp wash-heated dry-high temp wash-heated dry
    Please get back to me if you have any other questions.
    Kevin
    Posted on Jun 12, 2011
    oldTech2332
    • 2341 Answers
    SOURCE: I have a 6mth old
    Seeing where it will work when disconnected from drain, i would be looking at the house drain as the problema nd not the dishwasher. You can check these things.
    1) a clogged pipe under sink that it connects to
    2)do you hava airgap,its a piece that goes on the sink and hasa chrome cover about 2-3 inches tall,if ya have one of those(not all drains do) reomve cap by pulling off and depending on brand of air gap unscrew inner cap or push in the 2 tabs and pull out inner piece to check for a blockage
    3)if you dont have airgap is the drin hose under the sink always slooping down? at on point the drain hose should be higher that the level of the peice on the drain it attaches too,with corrogated drain hose its easy to pull it up and attach it under sink so at one point the hose is higher that the drain(disposer) nozzle
    Good luck, i hope this helps
    Gene
    Posted on Aug 04, 2011
    Kitchenaid dishwasher wont drain
    Allow the current cycle to complete. Draining will occur at the end of the cycle.
    Close and latch the door. The dishwasher will not drain if the door is not properly secured.
    Press the "Cancel/Drain" button on the dishwasher to start a two-minute drain cycle.
    Remove the knockout plug in the disposer outlet of the garbage disposal if the dishwasher drains into the disposal. Turn off the water supply and remove the drain hose from the disposal. Place the tip of a screwdriver on the plug and tap it lightly with a hammer to remove it. Replace the drain hose and turn the water supply on.
    Clogged Drain
    5
    Run the garbage disposal to empty it and clear the drain if the dishwasher drains into the disposal.
    6
    Remove the cover on the air gap on the sink or countertop. Turn the plastic cap counterclockwise to remove it. Remove soil from the inside of the air gap. Replace the plastic cap and cover.
    7
    Check the sink. Dishwashers connected to a sink will not drain if the sink drain is clogged. Unclog the sink. Contact a plumber, if needed.
    Issues With the Drain Hose
    8
    Check to see if there is a loop in the drain hose. The loop cannot be more than 20 inches above the floor. Disconnect the hose and loop it just above the floor. Reconnect the drain hose.
    9
    Remove kinks in the drain hose. Always use the new drain hose included with the dishwasher. Do not reuse old hoses.
    10
    Check the length of the drain hose. The hose should be less than 12 feet long. Replace with a shorter hose, if needed.
    Sep 01, 2012 | KitchenAid KAWS850LE Top Load Washer
    There are two hoses coming from my Bosch SHE45M06UC dishwasher. One is obviously the drain coming from the back of the unit, and the other is attached to the side looped and not connected to anything. I...
    Many people realize the dishwasher connects to a little hose on the sink, it is called an air gap. However, many people wonder " The air gap is there to prevent the water from being siphoned out of the dishwasher. When water flows through the drain hose, it creates a suction on the water still in the dishwasher. The air gap, makes a hole for air to get in. That way, the water only leaves the dishwasher when it supposed to, when it is pumped out. Another benefit of an air gap is that if the drain hose becomes clogged, the dishwasher can still pump out the water. Instead of flowing through the hose, as it should, it can flow out the air gap and into the sink.
    The dishwasher's drain line usually connects to an air gap mounted at the countertop level on the sink. The drain line continues from the air gap to either the garbage disposer or directly to the sink drain. If the drainage hose between the air gap and the drain is partially or completely blocked, wat
    Aug 28, 2008 | Bosch Dishwashers
    I just purchased an LG Front Load washer (Model WM2140CW). Best buy installed it. When I went to use it today, the floor flooded. Water was gushing out of the drain pipe (backing up). The LG drain hose...
    You may have a drain line restriction causing it to back up. Pull the drain hose up about 6 inches and try it again. If it does overflow again, you will need to call a plumber to clear the drain line out in your plumbing.
    Jun 16, 2011 | LG WM2140CW Washer
    Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
    the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
    May 01, 2011 | Electrolux Microwave Ovens
    My air conditioners is a everstar model mpa-08cr, and i need to instal the water hose on the side of unit.
    Hey there, just follow these simple steps then you'll be on your way
    To connect the continuous drain option. Remove
    the water tank from the cabinet. Inside the
    cabinet (water tank area) you will find a section of
    hose hanging beside the water tank, which is plugged
    at the end. Remove the plug
    from the end of the hose and install the drain hose connector
    (included with this unit) into the
    end of this hose section. Route the end of the
    hose (with drain connection) into the water tank,
    then through the hole provided in the face of the
    water tank. Attach a section of garden hose (to
    suit your continuous drain option requirements)
    to the drain hose connector. Place the open end
    of the hose directly over the drain area in your
    basement floor.
    Please make sure the drain hose
    section routed through water tank does not interfere
    with the correct positioning of the water tank inside
    the cabinet, or the will fail-safe switch mechanism will
    be activated, not allowing the unit to operate.
    Jun 19, 2009 | Danby DPAC8020 Air Conditioner
    Won't drain during the final cycle, water comes out on the floor
    CHECK THE FOLLOWING--
    1. Air gap / Drain hoses
    If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
    If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
    Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
    2. Broken belt
    Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
    Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
    3. Pump
    Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
    4. Drain solenoid
    Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
    5. Motor
    If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
    Replace the motor if defective.
    6. Timer
    Replace if defective (note: uncommon problem).
    May 31, 2009 | Kenmore Dishwashers
    Smeg dishwasher
    You don't say what you're missing. Smeg maintains websites with contact info to get what you need. www.smeguk.com is in the UK.
    What you should generally have is all sliding racks and a utensil holder. Included should be a drain hose and a manual. If a door panel is interchangeable, that is usually bought separately. Water inlet fittings are not included and neither is an exhaust drain connection.
    Dec 03, 2007 | Smeg DWI614 Built-in Dishwasher
    LG Dishwasher - drain hose replacement
    Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
    The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
    In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
    Hope this helps!
    Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
    Water draining is premature
    In my case, I had the same problem until I realized the drain hose was not looped high enough. Once I looped the drain hose higher than the dishwasher, the problem went away and it washes dishes perfectly.
    When the drain hose is installed too low, the water in the machine will only stay as high as the hose is installed because of the laws of physics.
    The same applies to laundry machines - that is why the drain hose is set to drain from a higher point than the drum of the washer.
    Good luck and Blessings!
    Apr 26, 2017 | Kenmore 17252 Free-standing Dishwasher
    KitchenAid KUDE60HXSS Builtin Dishwasher Logo
    20 people viewed this question
    Top KitchenAid Dishwashers Experts
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
