How do you reset the bale counter on h&s bale wrapper
2 Suggested Answers
  • 5097 Answers
SOURCE: Looking for a manual for
The manual is available here: http://media.tanco.ie/media/manuals/manuals/500-550-580/Old%20Machines/450s.550s%20&%20550a.%20%201996.pdf . Another copy is here: http://media.tanco.ie/media/manuals/manuals/500-550-580/Old%20Machines/450s%20&%20550S.%201995.pdf . The second version was easier for me to read; however I didn't check all of the diagrams for clarity.
I hope this helps.
Posted on Jun 01, 2011
Bale wrapper parts
We do not sell parts or have allocator service to find them.
Jul 20, 2017 | Garden
Need to change a bulb
If we had your full model number, we could help you more precisely.
The first step is to unplug the oven before changing bulbs!
See a diagram which helps you find & replace many GE cooktop and cavity light bulbs http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding: http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Nov 26, 2013 | Microwave Ovens
The tools reset the counters for the 'transfer belt unit' (TransferBelt_for2500W(E).exe), the 'fusing unit' (FuserUnit_for2500W(E).exe) and the '2nd transfer roller' (SecondTra
Refer the parts life counter reset.Every time you change the fuser ,imaging unit parts you need reset the counters.Touch the screen exe. nad reset.
Jan 24, 2013 | Konica Minolta magicolor 2500W
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Interior bulb out in microwave oven (built -in)
It all depends on that all-important model number. So without that, we can only give a broad, generic answer.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph, except to unplug the oven.
Nov 27, 2012 | Microwave Ovens
How do one enter to Service Mode level 3 of Canon irc3200
That level 3 mode is only for Canon engineers. What counter are you looking to reset? The counters for most maintenance items are reset in service mode level 1. The total counter for the machine cannot be reset without replacing the main controller pcb & the counter pcb.
Jul 25, 2012 | Office Equipment & Supplies
Minolta Di450 service code reset service code C1326
di450 . what is the solution of this code 1326?
Jun 09, 2011 | Minolta DI-2010F Copier
Counter wont reset after installing new imaging unit
One of the main chips has stoped working on the engine control board. So it does not blow up the fuse inside the Image unit and therefore can't reset the counter. Try changing the engine control board. part number is .. 116-1538-00
http://www.iteminconline.com/items.asp?Cc=7300P&ItemMoveby=0&Nbm=ZMD128%2FA&Pbm=119%2D6401%2D00&iTpStatus=0&Tp=&sTitle=&FromNav=False
Sep 18, 2009 | Xerox Phaser 7300DN Laser Printer
Computers & Internet Logo
David Payne
David Payne
