Question about Home
Imperial toilet cistern parts
Leaking Cistern Flush Valve
    Problem Solver:
  • 20 Answers
Go to the website and read for instructions on replacing the float valve or the flapper or the float
Posted on Aug 04, 2013
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
olddewsons
  • 38 Answers
SOURCE: Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
Posted on Jul 07, 2009
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
  • 978 Answers
SOURCE: how do i fix a cistern that is continually leaking
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
Posted on Apr 02, 2010
co7196
  • 3433 Answers
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
Posted on May 26, 2010
Where to buy parts for Fowler toilet cistern .
adjust the float
you are looking for the inlet valve or diaphragm
not as much fowler out here as caroma system parts
ebay
large hardware stores
plumber
Oct 30, 2016 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
I have a dual flush consort cistern N 81008, it keeps leaking into the pan after flushing .
You will need to replace the seal under the flush valve, need to dismantle cistern mechanism.
Oct 19, 2014 | Home
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
Dux toilet cistern problemsolving
can only be one of 2 things. the inlet valve is not shutting off properly and so the tank is overflowing into the toilet bowl or the flush valve rubber is worn out. you can find this at the bottom of the flush valve mechanisum.
Dec 04, 2013 | Home
Cistern leak
May 26, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
How do i fix a cistern that is continually leaking in to the toilet bowl? i have tried to open the cistern at the flush button unit but do not want to force open. tried twisting but is quite tight.
Apr 02, 2010 | Toto Aquia II Dual Flush Toilet
Can old style dual cistern be converted to new style 6/3
We have not solved the problem but after speaking to 3 Major Plumbing Supply Places
they have told us we have no alternative but to replaced both the whole toilet suite's
as older style pans don't match up with never models
Jan 04, 2009 | Home
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Home Logo
649 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
