Question about Seagate FreeAgent GoFlex Desk 1TB USB 3.0 Desktop External Hard Drive
Spins but makes a beeping sound and wont register.
When I start up my hard drive it starts like it is working just fine but then it starts to make a sound like its scratching and then it beeps every few seconds for about 30 seconds or so and then it shuts itself off. It is still spinning the entire time but it is not registering on my computer.
    New Friend:
  • 4 Answers
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
Posted on Jul 11, 2013
Seagate goflex 500gb not detected giving 3 beeps
I would say if it was spinning when it dropped, you are probably out of luck. There are services available for platter recovery, but they are quite expensive. Practice the 3 backup policy.
Feb 09, 2014 | Seagate FreeAgent GoFlex 500 GB USB 3.0...
How to remove beep sound after the system sound?
the beeps ate called post
Then what happens does it restart ? or just wont boot up ?
A bit more information please.
Not sure what you mean by 'when the hard drive beeps
does the hard drive start when you turn the laptop on
(at which point a do the beeps occur a single beep isn't unusual) and it stops when you turn the hard drive off - a beep then would be unusual.
I suspect you don't mean that, & if the laptop is working fine otherwise then I wouldn't worry about it or do you mean something else completely?
make sure the ram modules have secure seatings also check all power and data leads attached from motherboard to hard drive the same will apply for your graphics card
hope this helps
Oct 10, 2012 | Computers & Internet
Hard drive beeps
hope this helps
Sep 23, 2012 | ASUS Gaming G60vx Laptop Notebook Intel...
I have a seagate HDD, ST9120822A, Im assuming this is the drive in my laptop, and not what is inside the Buffalo Ministation I have hooked up to the laptop, does this sound right so far? Okay, so my...
You wont lose any contents of the external drive, but I would recommend to backup your laptop asap, which it looks like you were trying to do. Try to connect the external drive to another pc and see if it works, if it doesnt then you might need to purchase a new exteranl drive to backup you laptop. If it works then your laptop is having hardware/driver issues. Thats hard to say without testing it out. You might want to go to geeksquad but it will cost alot.
May 03, 2011 | Seagate Momentus 5400.3 (ST9120822A) Hard...
My acer wont load when i first turn on, or load,gives 2 loud beep
Sounds like the hard drive is going bad. Take out the hard drive and see if the laptop behaves like that if it doesn't then you know the hard drive is bad. If it still does then it could be a motherboard problem.. With it making those beeping noises when you first turn it on, they keyboard could be going bad because that would make a laptop start beeping like that as well.
May 19, 2010 | Acer Aspire 5100 Notebook
Maxtor 320 GB mini not working
If it shows up as a USB mass storage device it:-
1. Has power
2. It is connected to the computer via USB.
3.The correct software has been loaded for the hard drive.
The beep sound is probably an error message saying that the drive is not responding properly inside the case.
Hard drives Drives have been known to stick or not start up due to power cables or ribbon cables being dislodged. Try pushing these back into place.
If this is not the problem go to the Maxtor site (maxtor.com) and report the problem with the drive, not the USB which appears to functioning correctly.
Mar 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
My hard drive suddenly started beeping and stopped working
Your drive has failed. to try to get back some of your items put the drive in the freezer for a day. the chill will make the heads condense enough for about 3 hours of use for emergency backup.
Nov 07, 2009 | Hitachi 500GB External USB 2.0 Hard Drive
Hard drive will not spin.
I have the same problem with the same enclosure. I found out it is the power supply problem. It worked the first time out of the box. But when the black 12V/5V power supply box heats up, if I turn it off, and on again, my hard drive won't spin up. It had buzz sounds and tried to spin. I think they use a crappy power supply that can't supply enough current during drive spin up when temperature goes up.
My solution is to unplug the whole unit from the wall when you don't use it. That give the crappy power supply time to cool down, so next time when you turn it on, it'll start from cold. This solutoin worked for my 300G Seagate drive. For my smaller WD drive, it doesn't require cold start. I guess it makes sense, as bigger drives require more current to spin up.
Jan 19, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
Seagate freeagent 500g usb 2.0 beeps sound
I am so happy to say that i HAD the exact same problem.
Its an issue with the drive disk itself. Long story short because i dropped the drive the the disk was no longer able to spin fast enough to start the drive (the beeping sound actually being the disk trying to start spinning.
After spending literally the last 4-5 hours looking for a solution I found a unusual method that basically either works, or it doesn't there's no it kind of works. what you need to do is unplug the drive, then plug it back in and start Vigorously spinning it whilst keeping the drive horizontal (similar to what you would do when your unscrewing a light bulb).
You have to try and do so simultaneously with the beep and it should "kick start" the drive (AND OBVIOUSLY DON'T LET THE WIRE DROP OUT AS YOUR SPINNING IT AS YOUR COMPUTER WONT RECOGNISE IT IF ITS NOT PLUGGED IN).
I Know this method sounds far fetched but put it this way, 15mins ago I was working out how im gonna get hundreds of pounds to restore this drive, Now, i've just finished copying my informations onto a laptop from the drive so i can take this piece of plastic **** back to the shop :D.......
Never again Seagate and Thank God for letting me find a solution.
Feb 11, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent GoFlex Desk 1TB USB 3.0 Desktop External Hard Drive Logo
103 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
