Question about Samsung RS2630SH Side by Side Refrigerator
Freezer doesn't work
My SAMSUNG Refrigerator on the freezer side stoppped cooling, i have removed the panel to get to the fan, i cant see any reason why the fan doesn't working at all... Thanks, Andy
  • hout Aug 27, 2007
    It read 90 ohm across the red and black wires.
    Thanks,
    Andy
  • 725 Answers
Hi Andy you may have a bad (open) fan motor after unpluging the freezer check the motor see if you can turn it easly then unplug the motor and check it with an Ohm Meter. You should have continuity thru the motor.. let me know what you find out... krazytech
Posted on Aug 27, 2007
The bottom of the freezer gets cold , the Fridge gets nothing
The refrigerator compartment is cooled by the cold air from the freezer. This air is blown in through a vent between the freezer and refrigerator compartment by the evaporator coil fan in the freezer. If the vent is blocked or the fan is not working would be the reason that the Bottom is cooling but the refrigerator is not.
To troubleshoot, you must remove the panel that covers the evaporator coil in the freezer. You will need to remove the contents of the lower section of the freezer to get access to the panel near the bottom of the freezer. Once the panel is removed, you should be able to confirm whether the fan is spining. If it does not turn and it is plugged in and the refrigerator is not in defrost mode, then the problem is with the fan motor.
If the fan is spinning but you notice ice buildup on the coil, the problem is with the defrost circuit. Typically the failures are with the defrost timer not functioning or that the defrost heater has failed.
thanks for rating good luck
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Samsung RS2555SW - Refrigerator or Freezer is not cooling. I have removing the access panel inside the freezer. There coils have zero ice on them. The fan that is there does not seem to turn on. I have...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101 .
Oct 20, 2010 | Samsung RS2556 Side by Side Refrigerator
My frig is not cooling the temp is currently 68 but the freezer is fine any ideas
The refrigerator compartment is cooled by the cold air from the freezer. This air is blown in through a vent between the freezer and refrigerator compartment by the evaporator coil fan in the freezer. If the vent is blocked or the fan is not working would be the reason that the freezer is cooling but the refrigerator is hot.
If the fan is spinning but you notice ice buildup on the coil, the problem is with the defrost circuit. Typically the failures are with the defrost timer not functioning or that the defrost heater has failed. Hope this helps you.
Jul 22, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator does not work but the freezer works fine!
most fridges are cooled by the freezer. There is usually a fan in the freezer section that blows cold air in the fridge section vial some duct work. I expect that the fan has failed or that the air passage is blocked. look inside the fridge, near the very top on the side next to the freezer. You should see a vent/grill.
Jun 22, 2017 | Refrigerators
Freezer not working
Aug 26, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
100 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
