Question about Jenn-Air Kitchen Ranges
Jenn-Air Range Model S125 - need replacement clock/lens assembly
Have a Jenn-Air Range Series Model No. S125. Need Clock & Lens Assembly, Part # 712024. Searches tell me the part is discontinued. Any ideas where I can find one? Jeff Barbee jbarbee10@gmail.com
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
myob247
  • 1342 Answers
SOURCE: inserting ribbon connector into New electronic clock assembly
If it is a flat ribbon there will probably be a retainer clip that either lifts up or slides up and down to hold the ribbon.
Posted on Jun 15, 2008
SOURCE: Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Posted on Oct 11, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
  • 25 Answers
SOURCE: JENN-AIR SCE30600 COOLING FAN & OVEN LIGHT STAYS ON
small circuit board in back for fan & LIGHT BAD.
Posted on Feb 12, 2009
I have a jenn-air electric down draft slide in range. I had a power outage and now stove top works fine but no display or oven functions not even oven light.
You will need to replace the control board (clock assembly) on your unit. I see this all the time with power surges and it takes the control board out. Your model is a discontinued one and the part may need to be a special order. Here is a link to the part, call the number that is on the page and I am sure they may get it for you.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-clock-item-number-ap4088717.aspx
Nov 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn-Air oven model S125. I think it's about an 1987 model. The stove-top and flat/griddle work great but a few months ago I notice the clock quit working and the oven no longer works. Any...
The replacement clock is no longer avaliable from Jenn Air however in my appliance repair career i run across many still in the field and have included a link for this place in Ohio that will rebuild it and send it back to you. What you would need to do or have a company come and do is remove the clock and ship it to them.Their is a curcuit in the clock that ties into the oven and its very probable that the oven not working is related to teh clock. http://www.appliancetimers.com/index.php?page=db_timer_page&Timer_id=7052&Manufacturer=Jenn-Air&Appliance=Range-Stove-Oven&Model=712024 this is their link contact them and see if they can rebuild yours. If you, or even a repair company remove it to be shipped off to rebuild, take time and make a drawing of where the wires on it go so they can be reinstalled properly once its back to you freshly rebuilt.Also be sure to insulate all the wires taken off since some will be live and if come in contact with metal without proper insulation they could short out something else.
Aug 11, 2011 | Ovens
Jenn-air dual fuel jds9860aap intermitently display blinks like it lost power, reset and it will happen again. originally started with a f9 code that has not reoccured. If the oven is on, it will shut off...
Sounds as if you have a bad ground or nuetral wire connection. Unplug and check the connections to your control assembly and the pigtail on the range. I have also seen displays on Jenn-air go bad as well.Replace the clock assembly.
Apr 19, 2011 | Jenn-Air JDS9860A Dual Fuel (Electric and...
I have a jennair model sce30600wc, it was showing a f7 error code. if iI unplugged the oven it would usually work. Now the display does not illuminate but the oven works. DOes the keypad need replacing or...
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 14, 2011 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air Range: I am getting an F0 error.
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
Mar 28, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air range stove jsg8750 have a f1-7 error code
Hi there...
Error F1-7 means --
Replace touch pad or clock assembly (also called the ERC).
Good Luck!!
Jan 29, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Kitchen Ranges Logo
69 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
