Question about Sanyo DP50747 50 in. Plasma TV
Sudden change from Sanyo tv and Blu-Ray DVD
I have had my Sanyo tv and Sony Blu-Ray connected using a HDMI cable for over a year. Suddenly the tv stopped playing the audio from the DVD player. It now says the DVD is an AV connection and needs an additional red/white audio cable. We have switched out the HDMI cables and the problem still exists. Adding the red/white audio cable does work, but is not attractive since all of our wires are hidden except that. I feel like a setting on either the TV or the DVD was changed and is causing this issue. Any feedback would be greatly appreciated! ~Thanks!
  • 201 Answers
SOURCE: connecting a wii system to a sanyo DP26648 tv
It has to do with the type of input - Video2 and 3 are Component video inputs, requiring a 3- wire component video cable (Red,blue,green for video, red/white below for audio). Video 1 is for analog equipment (Yellow for the video, red and white for the audio). Unless your Wii comes with a component video out cable and jacks (same red blue green), you'll have to use video 1 for the Wii, and use Video 2 for the dvd. You'll need a component video (3-wire) cable for your dvd, which should have the jacks for it. You can use the present cable you're using for the dvd, but you'll have to change the connections on the back of the dvd to component video out, and you'll still need another 2-wire cable to connect the audio out on the dvd to the audio in on Video 2 on the tv.
Here's the manual for your tv - look on page 8 for these connections. the Wii will be an analog connnection, the dvd will be a digital connection.
Hope this helps!
Posted on Mar 13, 2009
  • 68 Answers
SOURCE: Sanyo TV DP32746 / not enough video inputs
Radio shack and others sell a extention box/ switch that will bring vetually extend the connections in the rear. That will ease the frustration. the switch will switch game and DVD too. go shopping
Posted on Mar 25, 2010
  • 901 Answers
SOURCE: I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
Posted on May 24, 2010
  • 702 Answers
SOURCE: problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
Posted on Dec 03, 2010
  • 5298 Answers
SOURCE: blueray dvd player to dp42840 hdmi cable hooked up
Check your set up again. Mine says the HDMI/DVI is HDMI 1 (and then connect the audio to the video 3 audio input).
I need a magnifier to read the label on the TV. You just need the only HDMI input that has (DVI) in front of the word Input.
I hope this helps.
Posted on Jan 07, 2011
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
May 30, 2016 | Televison & Video
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
Sanyo tv and Sony DVD player sound issue
If you post this query in a forum dealing with tv related issues, someone may be able to help you.
Apr 28, 2017 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Sanyo DP50747 50 in. Plasma TV Logo
32 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
