Question about Microwave Ovens
Ge microwave jvm1190by002 schematics - Microwave Ovens
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: NEED OPERATION MANUAL FOR 1998
Go to geappliances.com. Select "Use and Care Manuals" under the Search drop down menu. Type in your model number in the adjacent window and select "Go". Your manual is available in a downloadable .pdf format. I hope this helps you.
Posted on Jul 23, 2008
SOURCE: NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Posted on Feb 08, 2009
Have a schematic
Need to check with GE as these are not shared, Thank you.
Aug 09, 2014 | GE Microwave Control Board - WB27X10438
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
Oct 20, 2011 | Microwave Ovens
Schematic diagram
Have you removed the outer case? Sometimes the schematic (and other troubleshooting and calibrating procedure information) is located there. I found such info for a GE microwave (made by Samsung) in an envelope taped to the top of the inside case.
Sep 15, 2009 | Panasonic NN-S960BA Microwave Oven
No power
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 02, 2009 | Maytag MMV5207A Microwave Oven
Need a schematic .
I just today had to open up my GE microwave. After I took off the cover I found the schematic in an envelope inside.
The fuse should be right in line with the black or red (hot) lead coming in from the line cord. It may be a white ceramic cylinder with metal ends.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Looking fr wiring schematic JVM1490WH01
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 14, 2009 | GE JVM1490 Convection/Microwave Oven
Nov 15, 2008 | GE JVM1190 Microwave Oven
NEED OPERATION MANUAL FOR 1998 MICROWAVE-CONZECTION OVEN mODEL JVM1190BY002
Jul 23, 2008 | GE Microwave Ovens
Bulb replacment for GE Microwave Model JE1540wv002
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel. It has wiring, schematics, and troubleshooting info.
Yours will be found as JE1540WV02 (instead of 002) here: http://www.tinyurl.com/gv383
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
