Question about Oregon Scientific Oregon S48 Replacement Chain Saw Loops
100089-04+05 model replacement bar and chain
I have a Remington electric pole chain saw, model 104316-04, -06,-07. It also states the bar & chain as: 8" bar 104302-01/chain 104301S. Is there an Oregon bar/chain replacement number ?
I went to oregonproducts.com but could not find, best bet is to take chain to top notch small engine mechanic that can make chains and have one made. He may also hook you up with proper bar.
Sep 07, 2017 | Remington Garden
I have a Poulan 1.5 hp 14 Electric Chain Saw. I would like to remove the chain so I can get it sharpened. Need Instructions as to how to do this. Please if anyone can help.
You did not mention model so I am giving a general answer. Remove bar nuts number "19" The bar and chain will come off of the saw. Replace bar and chain with new. Loosen number "25" to enable new chain on the saw. Finger tighten the bar nuts "19" and remove slack from chain using adjuster "25". Tighten bar nuts with wrench.
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
Jul 05, 2017 | Poulan Garden
Chain is binding in the sprocket at the tip of the chain bar and will not sit down flush with the chain rails within the bar chain track
the chain roller at the end of the bar has probably worn out and as cutter bars are cheap replace the bar
Jan 07, 2017 | Garden
My Stihl MS 231 is not feeding oil to the chain how do I locate the problem and repair.
The chain and bar oil should feed from the reservoir to a small hole in the bar that feeds the oil to the bottom of the chain. If that little hole gets dirt in it, the oil won't feed to the chain. To clear the problem, remove the bar, remove the chain from the bar, and clear the hole in the bar and track for the chain in the bar. I've done this while out in the woods by just using a stiff dry piece of grass to push the dirt out. Once clear, replace the chain, teeth facing the correct way, and the replace the bar, and tighten.
Nov 13, 2016 | Stihl Garden
How to replace chain on chain saw?
you have to loosen your bar nuts. then there is a chain tentioner screw either on the front of the saw or on the side between the bar nuts. turn this screw until the chain is drooping fron bottom of bar. remove the bar nuts, cover, then the bar and chain. make sure the the cutters on the new chain face forward when installed. tighten tensioner screw until chain is snug against bar then replace cover and bar nuts. readjust chain if it is loose. lift unit from handle forcing tip of bar up. this takes away any chance of play in the bar.tighten bar nuts when satisfied that chain is tight. when properly installed you should be able to pull chain upward fron bar and the drive links should not come over the rail guide.
Oct 02, 2014 | Garden
Husquvarna won't cut straight replaced bar
What model Husqvarna are we talking about?
Feb 03, 2013 | Garden
Silver Streak chainsaw bar and chain
Replacement Silver Streak Bars For McCulloch Chainsaws Find your Chain Saw model, then click on the link to get the ChainSaw Bar and Chainsaw Chain for each model!
Special! Get 30% off when you buy bar and chain together!
http://www.jackssmallengines.com/chainsaw_bar_silver.cfm?manu_name=McCulloch
Jul 19, 2012 | McCulloch Garden
Replace chain onchainsaw
As you do not say what model this is we will talk about generic replacment, start by making sure the chain brake ( if fitted ) is off, do this by pulling the hand guard fully back to the top handle, next remome the nut/nuts holding the side cover on, wind the chain adjuster screw fully back and remove the side cover, loop the chain over the nose of the bar and take away, loop the new chain over the sprocket and lay around the guide bar, making sure it is in the bar groove,the sharp edge of the cutters on the top of the bar should face away from the saw ( as you look at the saw the chain turns clockwise ) if the bar adjuster pawl is in the crankcase make sure it sits through the hole in the guide bar, if the adjuster pawl is in the side cover make sure this enters into the hole in the guide bar as you re fit the side cover, re fit the side cover nut/nuts finger tight, turn the adjuster so as the chain touchea all the way around the guide bar, with a gloved hand pull the chain around the bar, now re tention the chain if required, now lift the nose of the guide bar and fully tighten the nut/nuts, run the saw, there will be an initial stretch, so re tention as required, do not over tention the chain, it should pull around the bar by hand readily but touch the bar rails, not sag on the bottom of the bar.
Feb 11, 2012 | Garden
Can not find the part number for the Husqvarna Rancher 55 model 967 05 29-00. We need to replace the bar and chain. (18")
In the UK we offered this machine with 13,15,18" bars,.325 pitch 050 gauge, the part no. for the 13" is 508926156, the chain is 501840456, the 15" bar is 508926164 and chain 501840664, the 18" bar is 508926172, and the chain 501840672.
Regards
Sep 11, 2011 | Husqvarna Garden
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
Oregon Scientific Oregon S48 Replacement Chain Saw Loops Logo
37 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
