Question about Ultima Shovelhead 96ci Engine for Harley-Davidson. Black Finish with Chrome Accents
96" ultima shovelhead engine pinging like marbles
Screaming eagle module # 32596-96
Hi Anonymous, for a free wiring diagram, please visit the website below. If you need more information about a specific electrical issue you can reach me at xlch@mail.com. Good luck and have nice a day. Harley Davidson Wiring Diagrams and Schematics
Jul 01, 2012 | Adly FXDSE CVO Screaming Eagle Dyna...
Oil line routing diagram 1980 shovelhead
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
diagram oil lines 1980 shovelhead Google Search
Oil lines on shovelhead engine Which is which
Jan 29, 2012 | Harley Davidson Motorcycles
2008 dyna fxdl 96 ci oil& ****** drain plugs
The oil and transmission drain plugs are on the bottom of the transmission. The engine oil tank is there. The center plug is the engine oil and the plug on the side is the transmission drain plug, I think. I don't work on the newer bikes and I'm not sure about which plug is which. I think I'm right though. I work on the older bikes (shovelheads and such) that the dealers will no longer work.
Good Luck
Steve
Aug 30, 2011 | 2003 Harley Davidson FXDL Dyna Low Rider
Hotpoint Ultima wt940 I load washing and set a normal program (say 40 degree wash). The door is firmly closed. I push start. Even though the LCD is on and I have pushed start - there is no...
'door' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Lost instructions for "Marble race
Here is a link to marble race assembly instructions.
http://slightlyorganized.com/2011/marblerace.html
May 14, 2011 | Toys
While playing marble Aggravation, a player had a "3" and a "4" on his dice. He wanted to move the "3" first, even tho he could move the "4". If he moved the...
Thank you for your question. It appears you are playing a modified version of Aggravation. The original rules from Hasbro call for the use of one die. The player must move only one marble the full amount on the die. If the player can not move the full amount of the die, his/her turn is over.
Other keys to moving your marble according the the original directions are:
  • You can only move a marble out of the "base" and onto the "start" space with the roll of a 1 or 6.
  • You get an extra turn when you roll a 6.
  • You can jump over or land on an opponents marble (aggravate it) but can't jump over or on your own marble.
  • A "aggravated" marble (one that has been landed on) is to be placed back in the "base" area to be started over.
  • You can use the "star" and "center" spaces for shortcuts. However, the center space must be landed on and the roll of a 1 is the only way off the center space.
  • You must move all 4 marbles into the "home" area by the full roll of the die to complete the game.
Here is a link to the directions: http://www.hasbro.com/common/instruct/Aggravation_(2002).pdf. My personal opinion on your situation with the 3 and 4 dice rolls is that he could chose which marble to move 3 and which to move 4. But, the full use of the amounts of the dice must be used and the total on one die can not be split by two different marbles (a 4 die can't be split into a 2 and a 2).
Hope this helps and doesn't "Aggravate" you more! :0) Have fun playing!
Jan 22, 2011 | Toys
I have been told that my car's Knox sensor needs replacement @ £300. Its an Audi A4. the car is running alright though. Is it essential?
If there is excessive vibration you can get a false positive on setting a code. This sensor helps your computer set the timing of the engine for maximun fuel economy and to keep it from pinging (sounds like marbles in the engine). If it is truly faulty the computer will go into fail-safe open loop mode which would reduce economy. If it is running as good as before and your mpg have not dropped and you do not hear any detonation then drive it and save the pounds. Make sure the wire to the sensor is connected well.
Jul 07, 2009 | 1996 Lexus ES 300
Dodge Ram 2500 engine ping
Your ignition timing may have advanced too far. Or it is now where it should be and is making more cylinder pressure during combustion causing the gasoline to ignite to early causing detonation or ping.
Make sure the ignition timing is correct. If it is try better fuel meaning the octane rating.
If you can go up to the next octane level. For example if you are using 87 go to 89 and see if it goes away. 3 of my wife's last cars a 1986 Honda Prelude, 2000 Neon, and a 2003 Neon had some ping under medium to hard acceleration. She switched to 89 octane and the ping went away completely in each vehicle. Each of the vehicle had a good deal of miles on them.
The 2003 Neon has 75000 miles on it now and runs great on 89 octane. About a year ago I tried 87 Octane in her car and the ping came right back.
Dec 25, 2008 | 1998 Dodge Ram 2500 2WD
96 toyota 4 runner won't run
try replacing your fuel filter and spark plugs, engine pinging results from a lower octane than recomended by the manufacturer and dirty gas being burned inside the combustion chamber. good luck!
Dec 02, 2008 | 1996 Toyota 4Runner
Ultima Shovelhead 96ci Engine for Harley-Davidson. Black Finish with Chrome Accents Logo
71 people viewed this question
Top Ultima Sport & Outdoor - Others Experts
Are you an Ultima Sport and Outdoor - Other Expert? Answer questions, earn points and help others
