Question about Sony Computers & Internet
Twisted laptop screen - Sony Computers & Internet
  • 369 Answers
Disconnect the power cord and battery. Hold down the power button for a minute and then connect only power cord.
Posted on Jul 11, 2013
Can I fix the vertical lines on my laptop screen by myself?
From my experience.. it will getting worst by time.. I suggest you replace the whole set of the LCD completely..
Dec 19, 2013 | ASUS N53SV-XE1 Laptop
My screen twist upside down how can i do. it boot
Hold down Ctrl and and Alt and then use the up cursor key to rotate the screen the right way up.
Regards.
Jan 15, 2011 | HP KP497U9 Notebook
My acer aspire notebook is only showing the bottom half of the screen, the top half is white
Grab your screen...right hand on top left hand on bottom. Apply opposite force and attempt to twist screen. If it corrects itself, gets better, gets worse etc...screen is getting ready to be totally shot. Been working on this LCD now for 6 months, just have to twist it here and there to get it to stop turning white. If it does nothing, it's shot. You have to get replacement screen. They are inexpensive and relatively easy to replace.
Jan 12, 2011 | Computers & Internet
I have a HP Pavilion dv4-1220us Laptop and the screen flickers at the bottom. A 1/8" white line will appear at the bottom of the screen-this happens after about 1/2 hour of starting it up. Later the...
Usually this means u have a damaged led panel or panel ribbon connector try a new LED screen first try ordering from Amazon get the numbers off the back of the screen
Jan 17, 2018 | HP Pavilion dv4000 Notebook
Vertical lines on screen
Hold one side of the screen need top and flex slightly (Not twist, FLEX) if the full screen appears and lines are gone, you may need to have this fixed by a shop or replaced totally.
May 02, 2010 | E-Machines M6810 Notebook
The laptop drop and when its turned on the whole screen is twist
CTRL+ALT+Up Arrow should give you a normal screen if the display is rotated 90 or 180 degrees
Jan 09, 2010 | Dell Latitude D610 Notebook
Laptop had a little drop..think the board is cracked.because the screen shows funny with all types of colors.but if i put some pressure on the left corner the screen shows perfect..talk to me..
The screen is probably damaged usually if you put pressure on the screen and it changes the display.The screen is bad had the same problem changed it works fine now,no more twisting.
Nov 19, 2009 | Toshiba Satellite A205-S5809 Notebook
Power Problem
Try to twist the laptop bottom when you turn it on. Some logic board issues are caused by loose chips, when you twist the bottom firmly, they will make contact and the laptop will start up. If that happens you can either twist it each time to turn it on or replace the logic board. If it's an AMD core duo based laptop, those CPUs sometimes tend to die from heat and cause an issue like this. Just replace the CPU they're 30 bucks on ebay. <a href=http://www.portatronics.com>Laptop Repair NYC</a>
May 17, 2009 | Fujitsu Siemens Computers & Internet
Screen
Defenitly the screen, it wouldn't start working when you twisted it if it was anything other than the screen. Not really much you can do other than pick up another screen off ebay. It'll run you about $150-$200
Jun 10, 2008 | HP Compaq Presario V5000Z Notebook
LG laptop K1-335EAB - Screen Display is going fuzzy!!
Hi, r u twisting the cable?? If yes then its gone bad, you wil have to replace it. let me know
Jan 09, 2008 | Acer Aspire One PC Notebook
Computers & Internet Logo
19 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
