My sharp acquos LCD HDTV goes between being normal and super fuzzy with colors almost seeming to blur the screen. It's about 7 years old and I'm guessing some piece is dying. Is this fixable or is it new TV time?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Its display panel should be checked. Visit the site linked here. It has screen shots to faulty LCD displays. See them and make it sure. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Posted on Jul 11, 2013
1Guru
  • 61 Answers
SOURCE: Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
Posted on Dec 12, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
  • 100 Answers
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Posted on Jun 04, 2009
  • 458 Answers
SOURCE: Big white blur, cloud like, Center of LCD TV
I have seen similar effects like this & it is usually due to a flaw in the screen. A replacement screen is the only cure.
Posted on Oct 05, 2009
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Posted on Jan 30, 2010
Sharp LED TV 3 years old stays dark on left side of screen for about 10 minutes after it is turned on. What could be causing this?
It seems to be capacitor{s}. Check the sharp website to see if there is any recall or special warranty on this unit.
Dec 15, 2013 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
Vertical lines of stuck pixels
If a LCD TV has vertical or horizontal lines, in most of the case the problem is a defective LCD panel.
Jul 01, 2017 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp acquos 42 inch lcd tv, which has worked flawlessly for about two years but, is now starting to show vertical lines that are green and sometimes they turn kind of red. They seem to appear...
The way the symptom was explained, the problem is with the LCD panel itself. Lines on screen are cause by some factors such as tft's or the control flexible contact that attached to the panel might become loose overtime, the flexible can be repaired but not at service station level. You will need to visit authorized sharp service station to have a look and get concrete diagnosis. they can decide whether the lines are repairable or not.
Jul 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HAVE A 42" LCD SHARP
You have likely shattered the LCD screen rendering it useless. Unlikely you can replace the screen for less than a new unit will cost.
Mar 19, 2011 | Televison & Video
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Blurred picture, after some warm-up it back to clear picture
If the problem doesn't return after the picture becomes normal, then it could just be due to the electron gun taking longer to fire up. I don't know how old your TV is, but TVs older than ten years typically take longer to warm up than more modern sets.
Jun 02, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 37" picture
Those lines are because of "Interlacing". a REALLY bad case of it. what are you watching when this happens?
Jan 02, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
