Question about Sewing Machines
Singer 50d toy
The bobbin on my singer model 50D is missing. WHat will work in it? Thx!
  • Sewing Machines Master
  • 7,365 Answers
Try a1sewingmachines.com and ask them what bobbin will work and see if they have one.
Posted on Jul 12, 2013
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
  • 188 Answers
SOURCE: Singer Merritt 8834-My bobbin Wheel is Locked :'(
pull it towards you. if this does not work take off the rubber but usually you put finger underneath and pull. or catch on side of bobbin winder. hope this helps try oiling it as well. the spring or hing bit.
Posted on Mar 26, 2009
Mongo32
  • 111 Answers
SOURCE: I have the Singer Sewhandy Electric sewing machine
I have the needles in stock at $1.50 each. Stepping Stones Quilts, 912-638-7128. Go to a gunsmith for the screw. cv
Posted on Aug 23, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
HELP PLEASE!!!! Need to figure out how to fix a Singer's Sewing Machine's drop in bobbin casing for my Singer 90s Special Edition???
Sounds like bird nesting or thread nesting (a user error), where there are thread "barfs" under the fabric. This is caused by the top thread not being seated in the tension disk. Remove the thread from the machine. ALWAYS RAISE the presser foot when threading the upper thread!!! Rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low numbers--you'll probably need to tweak it for your particular machine.
Remember, when experiencing problems, install a brand new needle. Remove the thread from the machine, RAISE the presser foot, and rethread from the beginning.
It also helps to always pull the bobbin thread to the top of the fabric, gently hold both thread tails in your left hand, and then slowly take the first couple of stitches.
Understanding Thread Tension Threads
Mar 10, 2017 | Singer Sewing Machines
How to take apart a singer sewhandy 50d to rewire it?
These machines are not user serviceable, no parts will be available to the general public.
Please have a trained service technician look at your machine. electrical issues and mechanisms do require service from time to time, especially with heavy use. If you use your machine frequently, have it cleaned and adjusted based on your use levels.
Cheers,
Embroidery Services
San Diego, CA
Jun 16, 2016 | Singer Sewing Machines
Have a singer H74 and the bobbin is stitching on the top side of the fabric also deco stitches are not coming our clear what am I doing wrong? Thx
Whenever that happens, it means that your top tension is tighter than your bottom tension, so your bobbin thread is being pulled to the top. That happens occasionally, and the solution is to loosen your top tension. Tensions are a BALANCE between top and bottom. Should this happen ALL the time, you could consider adjusting your bobbin tension, but when it happens occasionally, loosening your top tension works just fine.
Feb 28, 2015 | Singer Sewing Machine, Model H74
Singer 9420 bobbin case diagram
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
Dec 22, 2013 | Singer Sewing Machines
What parts to oil on singer model 50d sewing machine
here is a free manual, check and see if this manual is the right one
for the machine and it should have the information about oiling the
machine.
http://www.singerco.com/uploads/download/40_50d.pdf
Dec 29, 2012 | Sewing Machines
Mar 26, 2009 | Singer 7462 Mechanical Sewing Machine
Bobbin won't wind
Dec 23, 2007 | Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
