My laptop shuts down during bootup
My laptop keeps shutting down after a certain point in boot-up. I was recently forced to update after I wanted to restart my laptop. I let the computer update and I went to the store when I came back, I noticed the laptop was off. Whenever I turn it on it gets to a certain point in boot-up and then shuts off.
    Master:
  • 663 Answers
Which point in the boot up is that? are there any error messages? Can you still boot to safe mode without any problem? Please answer my questions so that I can provide you with a detailed troubleshooting steps.
David
Posted on Jul 11, 2013
  • Corey Geiger Jul 11, 2013
    There are no error messages, and its the point before windows 8 starts up. Everytime i hit f8 or shift + f8 to go safe mode, nothing happens. There are no error messages at all, it just unexplainably shuts down. Before the update, it was running fine, and the fan was never exerting any kind of force. The laptop is only 5-6 weeks old
  • David Greene
    David Greene Jul 11, 2013
    I suggest that you contact the warranty tech support of your laptop because you are still covered by the warranty.
2 Suggested Answers
  • 78 Answers
SOURCE: Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Posted on Feb 28, 2009
Laptop shuts down during Windows XP install
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 05, 2013 | Computers & Internet
I have a compaq pc with window's XP loaded. i did and update that window's wanted me todo after the shut down now it won't reboot , it keeps asking for the disk i can't find it what...
You need to do a system restore back to before the update. You can either access it during your bootup or, you should have the option through "all programs".
May 12, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 01, 2011 | Sony Computers & Internet
Computer freezes after bios screen on every restart.
One thing you could check is what order your computer is booting from. CD drive hard drive then other. Should be hard drive first. Go into the bios to do that. If you hold the power button down for 5 to 10 seconds the machine should physically shut down rather than unplugg. The unplug thing sounds like its in the power settings. But I've never heard of power settings being connected to bootup except for a password. Anyway a wild guess is check the bios bootup order.
Dec 31, 2009 | Toshiba Satellite® A215-S4807 PC Notebook
My Extenza 5420 won't complete updating and start up.
boot from the windows cd. select repair option. it will ask u" which windows u want to repair?". press 1. then in command prompt press the following commands.
c:/> fix MBR
c:/> fix BOOT
ignore the warnings u get in between when u enter the above commands
Sep 09, 2009 | Acer Extensa 5420-5687 Notebook
Toshiba A-215 will not boot after windows update
Hi there.
Boot the machine into safe mode by restarting the PC, as it boots up hit the F8 key until it giver you a sub menu with safe mode at the top and select that.
Hopefully the system will boot into safe mode, if it does you want system restore (if you use Vista a pop up window will appear on the right hand side of the screen, click on system restore, with XP just follow on-screen instructions)
All you have to do is select a date to before you performed the updated and restore from there.
Please keep us posted!!
Good luck and thanks for using FixYa!!
Mar 24, 2009 | Computers & Internet
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
Oct 27, 2008 | Acer Ferrari 4000 Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
