Question about Sony Mavica MVC-CD350 Digital Camera
Disc Error I am trying to finalize my disc and it is saying disc error. I was able to view the photos on the camera. Never had this problem before. DESPERATE TO GET THESE PHOTOS.
  • rosen367 Oct 16, 2008
    same problem, I can view all the photos via the camera itself. But the photos will not download to the PC, even after finalizing and transferring the CD to the computer drive. There are no errors showing up. Just can't transfer the photos. Methinks the index marks on the DCIM file are wrong and I can't figure out how to change them.
I had a similar problem, I was able to view the images on the camera but could not download them to my computer. I have an external cd drive, HP CD writer plus. This drive does not require me to finalize my CDs in order to download my pictures. With the damaged CD, I used a piece of software called BADCOPY to recovery the files(pictures) on the CD. I was able to recover all but one picture from the damaged CD. (I tried using the cd drive on my pc and the recovery software did not find anything, I had to use the external drive)
Posted on Jun 11, 2009
Error C:13:01 sony mavica MVC CD 350
Please help. I have the same error on mine. I can see images on the camera. I get this error and drive error when I try to finalize.
Posted on Sep 01, 2008
2 Suggested Answers
SOURCE: Disc Error
Repair will probably run from $180. to over $250. You can try to gently clean the lens with a Q-tip and cleaner.
This is a common problem with the Mavicas....The 400 and 500 models seem to last longer,but in the end..Sony has created another camera that despite it's price is a 'throw away camera" (just like the one's that used floppies)
Posted on Sep 30, 2009
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Card Error/Card Not Initialized Fault
Use a separate cardreader to download your pictures.
Aug 24, 2009 | Fuji FinePix S1000FD Digital Camera
Format Error code C:13:01
this camera is a gem! try finalizing the disc using nero burning software or any alternative. but dont try this on the disc that has your important pictures for safety reasons.
Jul 18, 2008 | Sony Mavica MVC-FD200 Digital Camera
Disc Error
Mar 17, 2008 | Sony Mavica MVC-CD300 Digital Camera
Disc error
if you get a disc error, DO NOT TRY TO REPAIR the data.
When you get a disc error, turn the camera off, turn the camera back on. When prompted to repair the data, select NO.
The camera should prompt you to Format the disk, select no.
you should go back to a normal camera screen, at this point push the FINALIZE button on the outside of the camera to finalize the disc.
This is your only option to save the data.
Never try to repair the bad data, it never works.
I have done this on two occasions, and it worked both times.
Dec 02, 2007 | Hitachi DZ-GX3200A DVD Camcorder
Disc Error
the c:13:01 is the error code. I was researching this same thing on my camera. It 'magically' fixes itself after anywhere from 1 minute (turn off, count to 20 and turn back on)to 1 month later. This time, I lost photo-ops with my kids and their cousins. Apparently, this is a loose connector - see link- and you can fix it by 1) smacking your camera around a little (no joke, this knocks the connector back, for a little while or 2) sending it to Sony for repair (about $350) or 3) follow this guy's suggestions and fix yourself. I haven't lost any actual photos, except the first time when this happened. Since then, I've put the CD in the computer and I've been able to pull off the pics. Can't use the CD again though, even if it's not full. The camera must mark the CD somehow to avoid overlaying photos(?). Anyway, here's the link and good luck :) http://www.pechorin.com/m/2003/07/12/SONY_C1301_ERROR-202719-43.html
Oct 21, 2007 | Sony Mavica MVC-CD200 Digital Camera
DirectCD and cd1000 and File Error viewing on cd1000
I've had some errors on my discs. What I've found is after you finalize them, if there is still room on the disc you can initialize then and use the empty space still on them. This can also fix some error, and I don't know why.
Sep 13, 2005 | Sony Mavica MVC-CD1000 Digital Camera
Sony Mavica MVC-CD350 Digital Camera Logo
476 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
