How to program my air conditioner thermostat
Don't know how to program my thermostat
    Problem Solver:
  • 14 Answers
Is there a model number on the control? I see it is a Carrier but we will need to track down an owners manual on line to figure this out. Visit my website www.60cubits.com and leave me some more information so I can help you.
Posted on Jul 11, 2013
SOURCE: Installing thermostat into my Rober air conditioner
Most typical wiring for Heat pumps are as follows: Red-R, Yellow-Y , Blue(common)- C, Green-G, White To either W, or W1, or Aux, Black-E, I will need additional info like: is your system a Heat pump, Straight a/c w/ elec. heat, and also what kind of tstat are you trying to hook up? Digital, mechanical?
Posted on Oct 16, 2007
  • 4736 Answers
SOURCE: I don't know if there
jbuck, Since your unit is a multifunction unit (AC, Heat & Dehumidifier) you don't have to darin any water. It uses an evaporative system, that exhaust the water/moisture thru the exhaust hose to the outside. With that said, there may be a rare occasion, that the condensation pan under the unit, needs to be drained. In which case, you will find the drain hole, covered by a plastic screw off cap, on the left rear of the unit (as you face the rear of the unit), next to the cord keeper. A small plastic bowl or pan that will fit under the drain hole will suffice. As, there shouldn't be that much water to drain.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 12, 2011
  • 4736 Answers
SOURCE: I need a master control
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Posted on Jul 13, 2011
  • 4736 Answers
SOURCE: I've lost the manual for
Your model has been discontinued, But, you can obtain an Owner's Manual by calling Delonghi Consumer Support at 1-800-322-384. They will usually email it to you as an attachment.
  • 387 Answers
SOURCE: Air conditioner model # A6T12F2A
leave the unit off for about an hour to let cool off its hot and kickingout on the over loads . this is probley realted to a power problem or low voltage problem in you area due to demand
Posted on Jul 24, 2011
Furnace runs 10 seconds and cuts off and will not run again till you adjust the thermostat runs for ten seconds and shuts off again
Don't keep in nutral position (50%) since the cut off and cut on ma be frequently. But your thermostat seems to be faulty as per your statement. Replace it.
Oct 25, 2011 | Weather King 12AJA4801AH Air Conditioner
We had a Honey Thermostat model # TH4110D1007 installed in our house, our technician did not leave an instruction manual with it and we don't know how to run it, can we get a website to download a...
yes just go to honeywell site. The address is inside the thermostat. Just pull the front part of the thermostat off and read the lable inside. Hope this helps.
Sep 06, 2011 | Honeywell Heating & Cooling
I have a Brivis buffalo 26 unit...the heating is on but it's blowing cold air the pilot doesn't seem to be light but I don't know how to relight it!
Try adjusting your thermostat, contact point possibly melt and welded by electric sparks. Replace thermostat control if contact won't get open.
Sep 02, 2011 | Heating & Cooling
My unit's fan works fine, but I think the compressor's not coming on. Problem has been intermittent; might be permanent by now. I'd like to check the thermostat and the capacitor, but I...
I do not think you can do this by yourself esp if you have never done it before and you do not know what to look for. there is really no way to do this without removing the unit from the case. I think it best to call a tech to do this for you . Sorry i cannot give you more on this .. Jon
Aug 08, 2011 | Haier HWR08XC7 Air Conditioner
My old thermostat had 4 wires connected to it, I have 5 wires white black ,blue,yellow and red. the wasn't connected to the old thermostat.Do i need to connect the red one to the new thermostat because...
locate the wires at the unit and hook them up in the same way . If it was not hooked up before you most likely don't need to hook it up now.. but check the unit where the wires connect to it.. let me know Have fun
Jul 24, 2011 | Heating & Cooling
Air conditioner model # A6T12F2A REV. A is cooling ok for a 2 to 3 min. at a time then it kicks down and blow warmer air out almost like it is reading like the room is cool and stops cooling maybe...
Jul 24, 2011 | Fedders Heating & Cooling
My air conditioner thermostat is showing a capital A. When I press the mode button it gives me options like 01, 02, Fn, r, D... What do I do? I have read the manual, but it doesn't help me at all
It would help me to know what brand & model number AC unit you have. Different manufacturers and models have codes that don't mean the same thing on each brand.
Please advise ... Thanks
Jul 14, 2011 | Heating & Cooling
I have a heat pump and I can't gret it to cool. It blows hot air when I am calling for cool. I checked the thermostat and i have it set to heat pump. I know it is a thermostat issue, but I don't...
Some newer heat pumps have a circut board that overrides your stat. Those you must program the stat as if it was a conventional. If your system is old here is the typical set-up. You will have this order. G=green wire, W1=white wire, O=orange wire, Y=yellow wire, C=blue wire, R=red wire. W1 is also called aux. G controls the fan, Y controls your compressor, W controls your heat, O controls your reversing valve, R is your 24v power, C is your 24v common. If this hookup does not work you will need to be able to understand your electrical diagram in order to fix the wiring issues and a professional might be required.
Jun 05, 2011 | Heating & Cooling
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
