Prostart remote starter is blowing one of the 12v battery red wires and not engaging the starter it works if you start the vehicle then use it to stay runing with the key off but wont start the vehicle
    Top Expert:
  • 12,223 Answers
See the diagram attached. and fix it. God bless you
Posted on Jul 11, 2013
2 Suggested Answers
seventonine
  • 72 Answers
SOURCE: how to program a remote control prostart in a jetta 91
Sounds as if the device is now out of the warrenty by now. any Devices like this are common to break down. Im surprised you got 6 years out of the bugger. the companys want you to buy new ones. you can try checking the prostart website fora replacement remote, but the cheapest way out is to goto a wall mart and get a new remote start.
Posted on Feb 16, 2008
How do I reprogram Prostart remote starter/car alarm after replacing car battery?
Try turning the Prostart off, then on with the little toggle switch. Check that the hood pin switch is working as it should
Dec 03, 2013 | Cars & Trucks
2004 Chevy Malibu question
Wouldn't expect ant codes with this issue. If you have a volt meter check for 12v on the small terminal of the solenoid. 12V should appear when the key is turned to the start position. If 12V dose not appear when key is turned to start your switch circuit has a problem. If you have no volt meter you can do this test by turning the key to the run position. Then tap the small terminal of the solenoid with a wire that is connected to 12Vs. This can be from battery or the hot terminal on the solenoid. If the starter dose not engage the solenoid part of the starter is not working. You got a bad starter take it back for a replacement. If the starter engages your switch circuit has a problem. & good luck with that.
Jul 13, 2013 | Cars & Trucks
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
2003 Chevy Impala 78,000 miles KEY WILL NOT TURN. - Car was running fine! - Turned off key. - Tried to restart and Key will Not Turn. It was jammed in the OFF position. - I removed ignition...
ur still in a security lock out with ignition[ key ] system u might have to have it towed to dealer for them to hook up vehicle[contact dealer and advise what is happening and also recheck new key] for reprograming or reset system..some vehicles if u try to start vehicle while in a security mode can get completely locked out of vehicle and if u replaced the whole ignition housing and not just the cylinder the housing is the reader the wiring that is around the housing cylinder tube is what reads the key and syncs with the vehicle if u put in a different one or the wiring is damaged vehicle wont start and will stay in security mode
Jul 02, 2011 | 2003 Chevrolet Impala
Wont start truck tried new battery also taken to machanic and they dont know......beeps like its starting but wont start vehical..prostart car starter
Check all your starter wires. Make sure they are all tight. Then If you can see the two posts on the starter solenoid (not the starter) jump them with a screwdriver. If starter engages it could be an ignition swich.
Nov 24, 2010 | Chevrolet Blazer Cars & Trucks
Starter stay engaged after it starts
If your starter stays engaged after the vehicle starts with the remote starter then, the vehicle's starter wire is receiving 12 volts, most likely from the remote starter's ignition or accessory wires. Check the connections to the vehicle's wiring: the battery wire is constant 12 volts, regardless of key position. The accessory wire(s) is 12 volts with the key at accessory and on/run (position 1 & 2), the ignition wire(s) is 12 volts with the key at on/run and start (position 2&3), and the starter wire(s) is 12 volts with the key in the start position (position 3) ONLY. Make sure that the remote starter wires are connected to vehicle's wires as directed by the Bulldog instructions.
Nov 17, 2010 | Remote Starter with Keyless Entry
Starter stays engaged
you need to tell us the make model and year of the vehicle and the kind of remote starter u have installed on the vehicle
Oct 09, 2009 | AutoCommand Remote Car Starter Add-On
How to trouble shoot starting system 98 ford crown victoria
Also check to see if there is power in the start wire form the ignition switch, the wire is a white wire with pink stripe, most likely not a common problem, but still something that could go wrong. this wire will feed the starter relay under the hood...
Sep 21, 2009 | 1997 Ford Crown Victoria
Starter Stays Engaged
check the wire that is hooked to the starter wire on the car. it should only show pwer in the start posision
Nov 19, 2008 | AutoCommand Remote Car Starter Add-On
Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Dec 01, 2007 | Scytek 2000RS-M Remote Control
Computers & Internet Logo
David Payne
David Payne
