Question about Vehicle Parts & Accessories
I bought a used dash cluster put it in my 03 chevy 3500 every thing worked I switched it off now the security system has shut every thing down what can I do to fix this I really need my truck
    Sergeant:
  • 203 Answers
What do you mean by a cluster? Please be more specific sir.
Posted on Nov 04, 2013
  • mikadot
    mikadot Nov 04, 2013
    A cluster is where you have a tachameter, speedometer and oil temperature guage etc bolted on top of the dash
1998 Chevy 3500 4x4 454. Will crank but will not start. Fuel pump is working and have fire to all plugs
Have a 98 would crank and run for a second.the problem was security.the ignition switch housing and module was faulty and causing the anti theft to shut off the injectors. look at that and your headlamp fuses as well as anti theft is tied to headlamp fuse
May 28, 2012 | 1998 Chevrolet C/K 3500
My gas hand and my temp hand doesnt work on 92 chevy caprice
IT MAY BE GM'S DESIGN CAUSING THE PROBLEM. THE MULTI-WIRE CONNECTOR THAT PLUGS ONTO THE BACK OF THE INSTRUMENT CLUSTER IS MOUNTED IN THE PLASTIC HOUSING BEHIND THE CLUSTER. SOMETIMES THE CLUSTER DOESN'T GO IN THE DASH QUITE FAR ENOUGH TO MAKE A PROPER CONNECTION, FOR SOME OF THE THINGS IN THE CLUSTER TO WORK PROPERLY. YOU WILL NEED TO PULL THE CLUSTER OUT TO SEE IF THAT SEEMS TO BE THE PROBLEM. WHEN YOU GET THE CLUSTER LOOSE & STILL IN THE DASH, TURN ON THE IGNITION SWITCH & WIGGLE THE CLUSTER & SEE IF THE FUEL GA. TRIES TO MOVE. IF IT MOVES YOU WILL NEED TO PUT RUBBER BANDS OR SOMETHING LIKE THAT IN BEHIND THE CONNECTOR TO BRING IT TOWARD THE CLUSTER A LITTLE MORE.
Jan 25, 2011 | Chevrolet Caprice Cars & Trucks
I have a 1997 Chevy crew cab long bed w/454 vortec engine.i was pulling a trailer when al of a sudden the motor started knockin and a light on the dash came on and started blinking.i never seen this...
Hi, I had a 1996 dually that did the same thing while pulling my 36ft. fifth wheel. I found that the oil pump drive/shaft had some how disassociated itself from the distributer. I fished it out with a magnet, popped in a new shaft, and it fired right up. I kept the truck until 2003. No new issues to report.
Dec 07, 2010 | 1995-1997 Chevy 3500 Truck Ignition...
2006 chevy trailblazer with electrical problems when you start it it goes into security lock down the lock and car symbol comes on the instrument cluster how ever the sycurity system is disabled at the...
This mornnig when i tray to start my trailblazer 2006 LT sudnly eletiric power cuted and there is now light,now engen start ,the key can not poled out please rocomand me
Nov 09, 2010 | Chevrolet TrailBlazer Cars & Trucks
2001 chevy express van 3500 while driving security light comes on dash then engine shuts down , once pulled off the road it will start back up.. did this 3 times on hour drive.. feels like gas pedal just...
You need to get the codes from the theft deterrent module.Usually a B2960.This will help in the diagnosis of the problem.Hope this helps.Good luck.
Apr 07, 2010 | 2001 Chevrolet Express
I have a 2004 tacoma. Remote starter doesn't work. Dash lights on right side of the dash are dim. Remote starter was pro installed 4 years ago. Any ideas? Thanks
look under dash for the unit, remove the 2 fuses in red jackets wait 2 minute then replace fuses
if you have a 4 BUTTON REMOTE CONTROL:
You will need to take the unit out of safety mode, to do this you will
need to ground the hood pin switch wire, then put your foot on the brake,
next hit any button on the remote and the clicking will stop. Then you will
need to take the hood pin switch wire off of ground and take your foot off
of the brake and see if the remote will work with the unit
if you have a 2 BUTTON REMOTE CONTROL:
need to put your foot on the brake, next hit any button on the remote and
the clicking will stop. Then you will need to take your foot off of the
Dec 15, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Must push start, then wait and push start a second time before any ignition occurs 92 f 150
check under the dash for a small toggle switch, somw have a red rubber cover on them, once you find the switch flip it off
Dec 04, 2009 | Bulldog Remote Starter & T-Harness Kit for...
03 Chevy Suburban says right rear door ajar when closed
Replace the rear door pin-switch if needed after testing proper operation.
It is telling the alarm the door is open all the time.
Most likely corroded terminals or wire.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Aug 29, 2009 | Chevrolet Suburban 1500 Cars & Trucks
I have a98 chevy pu the security light is off but the computor is showing security code and truck will not start
Try this Put your key in turn it on dont start wait 10 mins remove key wait 10 seconds repeat this a total of 3 times. If that dont work try a different key do the same thing. If that dont work a dealer needs to probably replace and reprogram your ignition switch and keys
Apr 07, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
1995 chevy chayenne 3500v8 2wd automatic transmission no shift
dude there is a wire that goes from your dash to the trans. that has a short I myself had the same thing wrong with my 1995 chevy 1 its like $450 from the 1500 i for got whats its called but its behide your dash go to the dealer and ask them to show you the wireing for the trans. and you will find it.
Mar 19, 2009 | 1995-1997 Chevy 3500 Truck Ignition...
Vehicle Parts & Accessories Logo
43 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
