Question about Dryers
I have a Lasko fan, PN 4914, there's electricity
    Top Expert:
  • 12,223 Answers
Try it otherwise the reset button is failed and need to test. Another problem is the bulged capacitor or burn capacitor inside replaced.
God bles you
Posted on Jul 11, 2013
4 Suggested Answers
farr64
  • 121 Answers
SOURCE: Lasko electric fan purchased from Walgreen's; called "wind machine"; turned on fan yesterday and blades barely move.
is the motor getting hot? try lubricating the main bearings.sounds like dry bearings .farr64
Posted on Apr 29, 2009
  • 365 Answers
SOURCE: My husband sat on the
It is possible that some of the electronics inside the remote are damaged from the added pressure put under it. If you have a cell phone with a camera, turn the camera on and face it to the front of the remote where the infrared light is. Press a button on the remote. If you see the infrared light start to pulse (note you can not see it without a camera, your eye can not see it) then the device should still be working, if there is no pulsing light then it is damaged and will need replacing.
Chris
Posted on Aug 16, 2011
SOURCE: fan light turns on but doesn't turn off with remote also fan doesn't go on with remote
Make shure your batteries are good in the remote. Also some remotes have little dip switchers inside the battery cover that are either on or off. They must be in the same position as the dip switches on the receiver in the top canopy of the ceiling fan or the remote & receiver won't talk to each other. Apart from that you will probably need to replace the remote control & receiver unit.
Posted on Dec 12, 2012
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
How do I know which wires go where on a lasko tower fan, I'm trying to use the lasko motor on a blower
You have to cut the blue wire, WAIT NO, the red wire. No the blue wire, yes cut the blue wire. Phew that was close. (How the hell is anyone going to know the answer this question? you took the think apart so you can see what the wires are for)
Dec 03, 2014 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko 2510 tower fan fuse
Follow the power cord. If they have a fuse, it will be attached to the cord.
Jul 02, 2012 | Lasko 2510 Tower Fan
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
How is the fan blade separated from the motor
Should be 2 screws attaching it to motor . 2 screws per blade. They may be above lite kit to where you can't easily see them and the screws are same color as blade arms .
Jan 24, 2012 | Lasko 3300 Wind Machine Fan
My Lasko E20739 blower fan works but does not oscillate. The small 120V motor that does the oscillating seems to be the problem.Please confirm and advise where can I buy s replacement motor Peter
i don't think it's going to be a motor issue, these fans have a round plastic gear in them that commonly go bad. remove the bottom cover by removing (5) phillips head screws, then unwind the power cord from the cord holder rembering the path, then remove the (3) large phillips screws, then just slide the base of the fan off and the gear is right there. if the gear is bad, you'll know cause there'll be pieces of plastic everywhere and the teeth on the gear will be rounded off. have fun. oh, for the part, i suggest contacting lasko at www.laskoproducts.com
Aug 21, 2010 | Lasko Heating & Cooling
My Lasko 40" tower has stopped blowing air - all other functions work as normal. Please advise.
Had the same problem with model 2551 - Lasko customer service said it was a failure of the electric motor that operates the blade unit. They do not sell replacement parts for their products, and if the unit is out of warranty (1 yr), your only resolution is to purchase another fan.
I disassembled my fan and discovered that the Decomin electric motor (#2033014) can be fairly easily replaced with a screwdriver and pair of pliers, but these motors are not for sale separately, even though they are still manufactured in China for Lasko and other product companies - they have their own website, but only sell fans, not parts.
May 22, 2010 | Lasko 2530 Elite WindTower Fan
Where do i get lasko box fan electric motor??
Lasko has an online parts resource for fans. Click the link below:
https://store.laskoproducts.com/ReplPartsStorefront/Web/c-2-fans.aspx
Also, a toll-free number (from USA locations):
1-800-233-0268
Apr 07, 2010 | WeatherWorks DB888 Floor / Box Fan
Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Apr 29, 2009 | Dryers
Dryers Logo
135 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
