Question about Panasonic TCL42U22 42 in. TV
Television making squeaking noise and flickering screen
I have turned it on again and it has gone blanck is it fixable
    Brigadier General:
  • 3,400 Answers
Use warranty if any.
Posted on Jul 11, 2013
`How do I fix my LG tv? It's making a high pitched noise and there is a black screen, is it fixable?
Get it to a tv dealer but my guess is its died. It may not be economical to repair but you may be pleasantly surprised and its a small job. LG are usually pretty good so I'm surprised its gone at this age.
Mar 30, 2015 | LG Televison & Video
Does squeaking coming from automoble water pump indicate water pump bearing is bad
If you take the belt off and there is no noticeable in/out, up/down, or side to side movement of pulley and there is no noise when rotating, a new belt may be all you need. Make sure you check ALL of the other belt driven components including idler pulleys and belt tensioner pulley. A worn tensioner can squeak also.
Feb 17, 2013 | 1995 Chevrolet Camaro
My screen colouration seems to have gone and there is allot of flickering? is this fixable and if so what is the estimated cost for this?
LG Zenith recommends replacing the Y-sustain, x-sustain and digital /logic board as a set. After you replace you will need to check the voltages listed on your panel. The cost if bought from second hand dealer like shopjimmy.com will be around 250-300 for the parts.
please leave feedback
Feb 21, 2011 | LG 42LC3R 42 in. LCD TV
TV Flickers
Could be a backlight problem best to have it looked at, but if it is out of warranty could be more cost benifical to buy new.
Mar 15, 2010 | iLO 3200 32 in. LCD Television
Flickering blue sceen
If it's a Gateway XHD3000, I may be able to fix it for you
I believe the problem is in the same board that causing the full strobing screen problem.
Cost is 150 to repair the problem board if it is fixable. No charge if not fixable.
You will have to pay round trip shipping for the monitor and power supply to Pennsylvania.
Ebays bammbammfran
Oct 04, 2009 | Gateway XHD3000 LCD TV
RCA 32'' TV making a humming noise
sounds like a shorted horizontal output transistor probably caused by the high voltage transformer or hot. it is most likely fixable but it will be costly.
Aug 19, 2009 | Televison & Video
Serpentine Belt Noise
it is more than likley your alternater belt will your car is turned off try pulling the belt back and forth if you can move the belt it needs to be tightened
Jan 18, 2009 | 1999 Hyundai Accent
TV grinding noise
A grinding noise in that model usaully means the light engine is defective or it could be the color wheel. But light engine is most suspect as there have been some issues with the light engine assemblies
May 11, 2008 | Televison & Video
Problem with Samsung HLN4385WX
These sets have a color wheel in them that has been know to cause this, Many times the customer heres the color wheel bearings failing and think it's a fan failing. The part BP96-00250a is only about $95.00 and since I have changed well over a hundred would call this a easy repair but for the newbie this might be a challenge
Apr 02, 2008 | Samsung HCL4715W 47" Rear Projection...
RCA tv Making a clicking noise
This is a power supply problem it may be as simple as a blown fuse or as complex as a malfunctioning IHVT (Integrated High Voltage Transformer). Is it worth fixing, only you can answer that I would estimate the cost from $100.00 - $500.00 at least.
Sep 03, 2007 | RCA D61W136D 61 in. TV/DVD Combo
Panasonic TCL42U22 42 in. TV Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
