Question about Danby DPAC7099 Air Conditioner
My Danby DPAC7099 used to have my room freezing now it feels like something might be wrong with the air conditioner it doesn't work how it used to & I only had it for a month & a half
It used to have my room freezing but now it doesn't work how it used to I think something might not be right?
  • 883 Answers
SOURCE: Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Posted on Jul 07, 2007
  • 1070 Answers
SOURCE: danby portable air conditioner
https://www.danby.com/registration.php?ln=USE&
Go to this web site to register your product.
Posted on May 20, 2009
  • 68 Answers
SOURCE: Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Posted on Aug 03, 2009
  • 36 Answers
SOURCE: Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
Posted on May 27, 2010
heatman101
  • 43501 Answers
SOURCE: Danby DPAC7599 Air Conditioner is not blowing cold
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
Danby portalbe air conditioner model dpac7099
Go to www.retrevo.com and click on manuals. Once you locate your product it should let you download it for free
Jun 26, 2012 | Danby Heating & Cooling
Cant find manual. How do you adjust tempature on this ? Thank you
First make sure that the unit is in Cool mode. (Press the Mode button: the choices are Cool, Dehumidify, Fan and Auto. You will see the mode at the top of the LCD display - Cool to the left and Auto above the temperature display) Then press the + or - buttons (or the up/down arrows on the remote) to reach the temperature that you want the unit to maintain. If you press both the up and down buttons together, the current set temperature will display for about 5 seconds. Then you can set the unit back into the Auto mode so that the mode and fan will switch on as needed.
Danby has the manual for the DPAC7099 on their site: http://www.danby.com/product/DPAC7099/4 . See the Literature tab. The direct link is http://www.danby.ca/cms/uploads/products/en_manual/dpac7099_web.pdf .
I hope this helps.
Aug 02, 2011 | Danby DPAC7099 Air Conditioner
How to i set up my danny dpac7599, i have nothing with it whatsoever except for the machine
Here is a link to the Owner's Manual for model # DPAC7099. As there is not a DPAC7599 listed.
I suspect it's the same or similar enough that the manual will help you.
http://www.danby.com/cms/uploads/products/en_manual/dpac7099_web.pdf
I hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC7599 Air Conditioner
Looking for an online manual for a Danby AC DPAC7099 model R410A
Karen, the following link is to the Owner's Manual for your Model Danby AC. You can download and print it for future reference. http://www.danby.com/cms/uploads/products/en_manual/dpac7099_web.pdf
Jul 26, 2011 | Heating & Cooling
I connected my brand new one Danby DPAC 7099 unit, but is not cooling the room. It only goes to 1 degree less than the actual temperature of the room and stays there forever. Is there something I should...
Your question "Should I wait before starting the unit, after bringing it from the store?" may be the answer to the problem. If the unit was turned on it's side or back when you brought it home in your car? Then yes. that is the problem. When AC Units, Dehumidifiers, etc are turned on their side or back, the refrigerant gas and the lubricating oil runs out of the compressor. It should not be operated, unit it's been setting upright for 6 to 8 hours. This allows all the fluids to run back into place.
If the above is the case. Turn the unit Off and unplug it for at least 6 hours. Hopefully, all the fluids will return to where they are supposed to be.
I hope this helped you and thanks for choosing FixYa.
Jul 23, 2011 | Danby DPAC7099 Air Conditioner
Danby AC DPAC7099. I need an exploded view or parts list. I can't find it anywhere. Basically what I need is the float assy..
Here is a link to your Owners Manual, in case you have misplaced yours, as well as a contact number for Danby Customer Service, where you can also purchase the part.
Customer Service: 800-263-2629
Hope this helps you get the float assembly you need.
May 09, 2011 | Danby DPAC7099 Air Conditioner
I have my hose plugged in and its draining alot of water. I am just using air conditioner
Depending on you ambient humidity, you can get a lot of condensate water. Think of it this way, your air conditioner is trying to cool the air, just like ice cubes in a glass. Wouldn't you expect to the outside of the glass to be dripping wet if you set it out for a while?
Jul 21, 2010 | Danby DPAC7099 Air Conditioner
I have a Danby portable air conditioner: DPAC7099. What is the garden hose for?
The drain hose is to drain the unit when in dehumidifier mode. You can get the manual on the link below just enter the # code then click on download manual. Page 10 of the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck
Jun 01, 2010 | Danby DPAC7099 Air Conditioner
Water spill
1) Press the POWER SWITCH key (Fig. G) to
switch the unit on.
2) Press the MODE key (Fig. H) until the DRY
indicator light illuminates on the control panel
(Fig. I). Each depression of the MODE key will
advance to a different mode setting (Cool -
Dehumidify - Fan - Auto )
3) If the room temperature is > 25°C (77°F), fan
speed can be adjusted. Press the FAN key (Fig.
J) to select the desired FAN SPEED setting. Your
selection will appear on the control panel. Each
depression of the fan key will advance to a
different fan speed (High - Med. - Low )
as shown in Fig. K. Otherwise fan speed is fixed
to low.
Note: The warm air exchange hoses must vent
inside the room when using Dehumidify mode.
Danby DPAC7099 Air Conditioner Logo
46 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
