Question about Archos 70 Tablets & eReaders
TROUBLESHOOTING YTH120AR ROPER RIDING MOWER
When I engage the PTO SWITCH THE MOWER DIES, I replaced the switch and the result is the same. Why?
When I try to engage Siri she says she cannot make the connection and I should try again later. I have iOS 10.0.2 installed. I have shut it off and restarted but the problem remains
Siri troubleshooting: Siri's not working at all on my device. Which iPhone/iPad models can run Siri? If Siri isn't working for you, the first thing to check is your model of iPad or iPhone - older devices can't run Siri, even if they update to a newer version of iOS. Siri is available on the iPhone 4s and later, on the iPad 3, iPad 4, and all iPad Pro, iPadAir and iPad mini models, and on the 5th- and 6th-gen iPod touch models. Plus the Apple Watch and 4th-gen Apple TV, of course Siri troubleshooting: How to turn Siri on If it's not working at all, Siri might be switched off. Go to Settings > General > Siri and make sure the top slider (next to Siri) is on, and green.
Sep 29, 2016 | Apple iPad Tablets & eReaders
Reset my kindle,
Dead battery. If you haven't charged it for several years it dies.
Unreparable although if you call kindle customer support they may give you a discounted price on a new or refurbished current model Kindle. They'll want your old one for parts.
Jul 02, 2015 | Tablets & eReaders
My ipad will not switch on and no charging battery shows when connected to charger
Try another charger...
it could have died.
if same result... Take iPad for repairs
Apr 19, 2015 | Tablets & eReaders
My sons polaroid tablet keeps freezing and I can't do anything until it dies. Please help
Try holding down power on switch for 5-10 seconds and see if you get a power down screen popup. If that doesn't work, look for a small hole on the back of the tablet or side that seems to have a piece of metal at the bottom of the hole. Poke this reset switch gently with a toothpick and see if the tablet resets (You can also check the manual for reset information).
Dec 03, 2014 | Polaroid PTAB750 7" Android 4.0 Childrens...
Ipad troubleshooting
Try resetting the iPad, by pressing both the home button and the on / off switch, till the iPad switches off. (can take about 10 seconds)
then switch on with the on / off switch. the white apple loge should appear and within one minute it should work again. If the light stays off, contact an Apple store and ask a Genius on the Genius bar.
Aug 28, 2014 | Apple iPad 32 GB WiFi Tablet PC
Zeki tablet troubleshooting
I guess you have a problem with the lcd screen, but before taking it to the technician try to switch it of and on again.
Aug 19, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
No sound coming out
When you use headphones, a switch usually engages to silence the internal speaker. Try plugging/unplugging the headphones a few times and let me know if that fixes it. B)
Mar 26, 2014 | Irulu Tablets & eReaders
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
TC1000 Stopped working
Whatever happened? Fixed? still not up? Trashed?
Nov 30, 2007 | Compaq tc1000 Tablet PC
Tablets & eReaders Logo
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
