Question about Chevrolet Vehicle Parts & Accessories
2004 trailblazer
I have 2004 trailblazer that isn't blowing ac/ heater at all, any suggestions?
Obviously has to be diagnosed
You can't do that without years of experience
& factory manuals,so a repair shop
Posted on Jul 11, 2013
Heater not blowing hot air in cabin
Check the coolant level. Check for leaks. Next would be clogged heater core(doubt that 2004) next would be the water pump. Kind of doubt that also, 2004. But if you have leaks?
Dec 25, 2014 | 2004 Chevrolet TrailBlazer
Driver side blows heat , pass blow cold on ac
I would suggest you work from a factory
diagnostic manuals,I wouldn't even go to the vehicle
the first time, without info on any system or problem
All your saying is your not familar with the system & you
you can't be,you need your reference material & wiring
diagrams each & every time, so you have somewhere
to start your testing
Jul 24, 2013 | 2004 Chevrolet Silverado
The heater isn't putting out hot air
check to see if there is plenty of antifreeze in radiator , may have a air bubble in system .
Jan 28, 2013 | 2005 Chevrolet TrailBlazer
My AC and Heater blower isn't working in the front vents of my 2004 Chrysler Pacifica what is the problem
If the air blows out of all of your other vents then you have either had an actuator go bad which controls which ducts the air flows through, or the shaft that has the "flap" on it has popped loose and no longer moves which will only allow air to go to the vents that are not locked. The easiest way to find out would be to get under the dash and start at the fan and trace air flow til you find the problem.
Sep 11, 2012 | 2004 Chrysler Pacifica
Heat or ac don't blow air out vents
My a/c doesn't blow air through the front vents just through the sides andbottom
Jul 31, 2012 | 2004 Chevrolet TrailBlazer
AC blowing hot air one side & cool air other side
If it has dual zone temp. control it is most likely the heater control panel.
Jun 01, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
I have a 2004 chevrolet trailblazer. It has dual heat select controls. The passenger side is blowing cold air when set to 'hot'. The driver's side seems to be responding normally. The dealer...
most likely the actuator is sticking which still can involve dash coming out but this should be around 700 dollars. try unhooking battery for a few minutes this will cause actuators to relearn positions and can free a sticking one
Sep 22, 2011 | 2004 Chevrolet TrailBlazer
My 2004 chevy trailblazer flash or hazard is not flashing.
firstly check that the fuse isn't blown, if the fuses are good then the flasher unit may be faulty & needs replacing...... cheers
Aug 21, 2011 | 2004 Chevrolet TrailBlazer
Ac/and heater fan does not work . No lights on instruments
Hi, since the whole panel is dead, I would check the 40 amp HVAC BLOWER fuse under the hood. Please get back to me if either that isn't the problem or the fuse blows again.
Jul 24, 2011 | 2002 Saturn L-Series
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
