Electolux front loader washer massive vibrations
Our machine stopped and I found some bobby pins in the pump, after cleaning it out, it nows spins for a few seconds and then stops. I did drain all the water, and sprayed WD40 on the shock absorbers (access under the machine) and the springs seems attached in the right place. The machine works well through a normal cycle - without clothes - however it vibrates itself all around the room before switching itself off and then unusable when loaded with normal amount of washing in the drum.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
There are 2 large springs supporting the top of the drum, I would say there is a good chance 1 of those has pulled loose, or perhaps cracked or broken the securing hole.
Posted on Jul 11, 2013
  • 54 Answers
SOURCE: Noise at end of spin cycle
on one end there's a clip you hold in then grab the nut end and pull. hope this helps
Posted on Feb 15, 2008
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Posted on Mar 07, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
How to fix the pump in maytag neptune washer
Remove the back panel there are four screws in panel. the pump is acessable on left side facing back. The pump is bad or you have something stuck in the pump.eg.bobby pin, bra support wire, and have found coins in them also. Have towels handy to absorb the water.
Feb 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Hello i have a maytag neptune front loader that ive had for only two years and it was making an extremely loud noise when spinning now it has stopped spinning completely and my clothes are still soaked...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Feb 18, 2011 | Maytag Washing Machines
Spin cycle massive vibration everytime. Size of load doesn't matter?
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a bosch maxx 1000 (wfl2000au/30) machine will not spin. pupm impeller was jammed by a bobby pin. i removed the bobby pin. when machine is on spin cycle only the pump opperates. does not spin at all....
If there is no water in washer, and it will not spin, I suggest you remove the motor, and check the brushes.
If they are less than 3 or 4mm long, they need replacing.
Hope this helps.
Dec 05, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Mar 04, 2009 | Bosch WFK 2401
Washer whines any time the agitator is moving or spinning, not while filling, etc. What might this be? I live in the middle of nowhere and my appliance repair man has died of old age. Literally.
We took the housing off the washer and started the machine, albeit carefully, and followed the squeal. Sounded like the water pump thingy in the front. Took that off from the machine but still connected to the hoses and the squeal stopped. Dipped and drained machine, removed water pump thingy and looked inside. Found a really beat up hairpin/bobby pin lodged inside! (I have two teen daughters at home) Removed pin, put back together, and wah-lah, a few hundred dollar miracle, no squeal!
Nov 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Jul 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
May 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
