Question about Craftsman Garden
Replacing grass deflector tension spring 42" cutting unit
I am replacing the grass deflector
    Sergeant:
  • Craftsman Expert
  • 369 Answers
Ok. What do you need help with?
Posted on Jul 07, 2014
  • 10865 Answers
SOURCE: 42 inch craftsman. Replaced bades and now have a
OOPS! I hate to tell you but you most likely put new blades on that were too short. Check your manual and get the proper length blades. If you still have the old ones, check them against the new ones and you will see that they are shorter resulting in the uncut grass in the center.
Posted on Jun 23, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
  • 731 Answers
SOURCE: Cratftsman Lawnmower; 16.5 horse; 42
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
Posted on May 19, 2011
lilgusher28
SOURCE: I can not get a new belt to tighten to mower
yeah check that spring on right top on deck
Posted on Jul 20, 2012
  • 6468 Answers
SOURCE: Can't get enough tension on pto belt
make sure you have the proper belt
Posted on Sep 25, 2012
Replace spring on grass deflector
you have to hold the spring and deflector in the loaded position (forcing against the spring force) while you feed the pin thru the deflector and spring and back thru the deflector and intor the deck bracket.
Jul 24, 2014 | Craftsman Garden
How do I replace deflctor shield
You have to hold the spring and deflector in the loaded position (forcing against the spring force) while you feed the pin thru the deflector and spring and back thru the deflector and intor the deck bracket.
Jul 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Bled on cutting deck spins free and will not cut grass
I assume you mean the blade on cutting deck?
Is the pulley that drives it still firmly connected to it? (I mean the pulley and the blade spin together as one, and not independently)
If the blade is loose on its spindle check under the deck for damage, and that the blade securing bolt(s) are intact and tight.
If the problem is that the pulley isn't getting driven by the deck belt, that is a different story. Most likely the deck belt isn't getting enough tension to grip the pulley. Check the tensioner is working properly and the spring is still hooked up and working.
Sep 02, 2013 | Craftsman 42 in. Precision Cut Plus 24hp...
How spring goes on deflector shield
Please wear eye protection for your safety before performing this task since there is a spring that is under load! Take a pair of side cutters and cut the one way lock washer located on the font side of the shaft. (Facing Towards Front of Tractor). It should be black in color. Take a pair of pliers or vise-grips and pull and twist the rear part of the shaft that goes through the plastic deflector and work the plastic deflector up and down while you work the shaft out. As you're working the deflector shaft out, take caution as the spring will pop out of place. To install new deflector, place spring between plastic deflector and align it up to the hinge openings on the deck. Make sure the "L" tab is inserted in the open slot of the plastic deflector. Tilt the plastic deflector towards the back side and start to insert the deflector shaft from the back and wedge it in about close to half way in. Take the front part of the spring that has the rubber tab (to protect deck paint) and twist it counter clockwise so the rubber tab is pointing towards the left side of the deck. Push down on the plastic deflector assembly and continue to work the deflector shaft all the way through to the font hinge opening. Once the shaft has passed all the way through the hinge opening, take a 9mm or 10mm deep well quarter inch socket and tap the new one way lock washer that can be purchased at your local hardware or Home Depot location. Use a soft mallet hammer to do this so you won't damage the chrome finish on the socket. Good Luck and Let Me Know How it Turns Out.
Aug 31, 2013 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman Lawn Tractor runs but does not cut grass?
Above deck, below tractor is black cable which has spring on end and goes to a tensioner pulley.
This cable should be locked into a bracket with a retainer pin and then its spring tip (rounded) goes around the top of tensioner pulley axle then a small washer on top and then retainer pin goes through this tensioner pulley axel shaft tip to hold spring onto it.
Jun 13, 2013 | Craftsman Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
How does the sping go on the grass deflector?
U need a diagram ver hard to explain but try this line up your spring in the grooves of deflector put ththem agaibst the deck in between whereyou will nect slide the long pin that goes through the spring and the deflector you can find a diagram on sear parst online web site type in your serial number and model or look in your manual it takes about 2 minsto installjust position correctly and slide in pin ask for second pair of hands
Joe
Oct 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
Apr 06, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
80 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
