Question about Metrologic Instruments Metrologic ScanPal 2 (SCANPAL2CB) Portable Terminal
Error stating terminal not ready - Metrologic Instruments Metrologic ScanPal 2 (SCANPAL2CB) Portable Terminal
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Hey i got symbol ptc 710. its got error 67>. how can i fix that
That is probably not an error, these devices use an operating system called Tcal, 67 is the version. The device is ready to load applications.
Jul 17, 2011 | Symbol PTC 701 Portable Terminal
I have an F1 error code. The manual states that this means the inside and outside units are not communicating. What should I look for
F-1-No communicationbetween indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Sep 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
How do I get the printer from off line to ready
if you press the online button and it does not go into ready state, it means you have an error, which needs to be fixed first. look at the error light condition that you have and check in the manual, or reply to this email, and I will give you a better idea.
thanks
Aug 30, 2010 | Brother HL-2070N Laser Printer
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
Press "STOP" TO EXIT.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
ERROR
HD detection error: the HD cannot
be detected; the machine fails to turn
ready; an error state is returned.at time of Bootrom
processing, BARSAC is started up and
mounted (usrIde).
[Timing] once at power-on
Jul 28, 2009 | Canon imageRUNNER 7200 Copier
Kyocera KM-1510
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
Dec 30, 2008 | Kyocera KM-1505 Copier
Posiflex 6000TP Jiva Pos terminal with Win 2000 Pro OS
cooled boot the reload OS if not your PT600 over heated I have six for sale If you cant mix your problem!
Dec 05, 2008 | Computers & Internet
Metrologic Instruments Metrologic ScanPal 2 (SCANPAL2CB) Portable Terminal Logo
50 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
William Robinson
William Robinson
Sandeep Kumar
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
