has it been replaced???????????????????????/
Has the drum been replaced? If not reset code for drum without replacing the drum is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items, then the copier will adjust certain voltages to certain items such as the drum as those it is new because you reset the counters when in fact the drum is old and so you might be codes and image problems.
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
