Question about Water Heaters
Fsg 30 216
Specs
Reliance 606 electric water heater is making a pulsing noise. What could be the cause?
Your heating element is bad get tha specs for your hot water heater and get one at lowes or menards
Aug 31, 2016 | Reliance Water Heaters
How do i replace a broken grommet
measure the diameter and put that info into goggle or yahoo or bing or other.
Unless the inner - open - diameter is an odd spec it should be easy to find
Nov 08, 2014 | Water Heaters
How to Test g6a-8a igniter coil .
Get a service Manual!!!!!!!!!!!!!!
Test voltage at slip on lead to igniter from power source. If you have Voltage @ lead within Spec values the igniter is bad and must be replaced
Sep 08, 2014 | RTO Atwood Water Heater - 6 Gal LP
Not getting spark from electrode. i have replaced it and still no spark. what to try next?
igniter coil could be bad.it creates a high voltage spark across the electrode. be sure electrode is set to specs.
Jun 07, 2014 | RTO Atwood Water Heater - 6 Gal LP
Where can i download the manual for a thermor water heater"?"
www.reliancewaterheaters.com/lit/spec/2006ServiceHandbook.pdf
May 07, 2014 | Reliance Water Heaters
I have a 40 gallon electric reliance water heater model no. 8 40 2ARS8 - serial no. M94566434 that I need dimensions for so that we can replace it with a new model. Thank you.
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
Reliance is an AO Smith company
http://www.reliancewaterheaters.com/prod/elec.html
Link above goes to Reliance electric water heaters
I cannot find your model number
The serial number seems to show it was made in 1994, so the spec sheet would be difficult to find
You must have bought a good heater and taken care of it for it to last that long.
http://www.reliancewaterheaters.com/lit/spec/electric/R606E0510.pdf
Typical 40 gallon Reliance electric:
18" x 59-1/2"
20-1/2" x 44"
http://www.reliancewaterheaters.com/lit/spec/electric/R909E0510.pdf
Self-cleaning type Reliance 40 gallon
19" x 60"
21-1/2" x 46"
The size of your heater can be determined by measuring the height, and then measure across the top to get the diameter. Your measurements will be close to the numbers shown above.
Oct 29, 2010 | RELIANCE ELECTRIC WATER HEATER
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Oct 22, 2010 | Rheem Water Heaters
Small seepage underneath hotwater heater.
soetimes its gaskets around flanges and heater element fixings that fail
have a good look round after drying the area with tissue etc.
leave a dry tissue round the based so you will see tell tale trace stains where its perhaps leaking from
Nov 29, 2008 | Water Heaters
Water Heaters Logo
20 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
