Question about Microwave Ovens
Danby microwave m # 1153
No heat,light or turntable movement all functions on pad seem to work, when door is opened turntable works.
  • 1 more comment
  • Malecook Dec 29, 2008
    Does not function at all. No sign it is receiving electricity. Yes, we checked the outlet, it works. So what's wrong?
  • cjmmam Jan 25, 2009
    Power works and turn table turns but does not heat. Is the Magnatron bad, or capacitor or diode?
  • WANNENBURG Apr 08, 2009
    NO FAN SOUND, NO DISPLAY, NO REACTION WHEN ANY BUTTONS ARE PRESSED, NO LIGHT INSIDE BUT TURN TABLE TURNS WHEN THE DOOR IS OPEN. FUSES OK.
Danby dmw11536 my microwave oven start beeping all the time. i can start it if ipush the cancel button, ordinarely once but sometimes it won't start unless you unplug it. also disylay shows 1:00 but keep time of cooking anyway. after it returns to beeping all the time, sometime you have to leave it unplugged for a couple of hours. danby dmw11536
Posted on Sep 11, 2009
  • Microwave Ovens Master
  • 9,156 Answers
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
My microwave is not heating food although everything else seems to be working. What do you think is wrong? Would this be a costly repair?
Sounds like the magnetron tube has burned out so you don't get power. It's the heart of the microwave. Time to shop for another, not worth repairing.
Oct 02, 2018 | Microwave Ovens
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
When you try to heat something the timer works but there is no heating. there is no cooking , but the cook light is on. no turntable movement either
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';-
Apr 16, 2011 | Danby DMW1146SS Microwave Oven
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Jan 23, 2009 | Danby DMW1153 Microwave Oven
Microwave turns on, but no heat or turntable movement
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure, but it may also be a broken switch mount. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. It is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 or at http://www3.sears.com
Mar 19, 2007 | Kenmore 62702 Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
858 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
