Question about 2010 Nissan Frontier Crankshaft Position Sensor Standard
Po335 ckp-sen/circuit i need to know were i find this in the engine, cause i need to fixe
You need to have the system component tested
to determine if the Crank Sensor is bad,not throw
parts at it.
OBD Codes have nothing to do with telling you to
replace a part or that they failed
Leave that to a pro with the proper knowledge &
test equip
Posted on Jul 11, 2013
I have a 2007 ssangyong rexton, it cuts out when hot? theres a few fault codes come up, p1677, po675, po335 po372, any help would be much appreciated...
1677 may be Drive by Wire - MIL Circ. Short to B + Ssanyon is not listed as they use OEM parts.
0675 Cylinder 5 Glow Plug Circuit/Open
0335 Crankshaft position (CKP) sensor - circuit malfunction
0372 Timing reference, high resolution signal A - too few pulses
Jun 26, 2017 | SsangYong Cars & Trucks
I have these codes reading now po700 po335 and po727 any idea what to check first on 03 kia sorento. my car lost power then shut off, then wouldn't start
p0335 is a crank shaft sensor error. This sensor is what tells the ECM when to send spark to plugs. That is why it wont start.
Apr 02, 2016 | Kia Cars & Trucks
My car is nissan Terrano 1996 Engine 32QD i made diagnosis after showing engine check blinking and go away, the result is 0047 CKP SEN/CIRCUIT what should i do then ? please help
Hi Josephath, Im AL the owner of Big As Auto Repair.
Josephath, anytime the code relates to a CIRCUIT that means that it could be a broken wire or the connector going to the Crank Position Sensor "CKP" . The connector could be corroded or a broken wire or a damaged terminal inside the connector. It also could be the CKP Sensor has gone bad. It also could be the computer that controls that circuit. I would start with a new CKP Sensor clear the codes and see if it come back. Hope this helps and please visit my auto-repair-website at: http://www.bigasautorepair.com/
Nov 27, 2015 | Nissan Cars & Trucks
I replaced the engine control module
code po335 refers to crankshaft position sensor(CKP)--circuit malfunction===causes wiring--CKP sensor --ECM
check the air gap and rotor security . Check for dirt in the air gap. Change CKP sensor.
code po113 refers to intake air temperature (IAT) sensor ---circuit malfunction===causes ---wiring open circuit /short circuit to positive ---wiring short to ground---ground wire defective--IAT sensor ---ECM
Mar 25, 2014 | Hummer Cars & Trucks
Po335, engine ligt on, slip and vdc brake light on 2005 armada
Error Code: P0335
Description:
Crankshaft Position (CKP) Sensor - Circuit Malfunction
Possible Cause:
Wiring.
Crankshaft position (CKP) sensor.
Engine control module (ECM).
Mar 25, 2014 | 2005 Nissan Armada
Iget a code po335
code p0335 refers to crank shaft position sensor(CKP)- circuit -malfunction cause may include Wiring---CKP sensor Engine control module
Mar 23, 2013 | Mazda 626 Cars & Trucks
2005 nissan altima codes p0725, po335. how to fix
P0335 Crankshaft Position Sensor A Circuit Malfunction P0725 Engine Speed input Circuit Malfunction
  1. Using a scan tool, check if, when engine is running or cranking, that there is an RPM signal.
  2. If there is no RPM reading, then visually inspect the crank sensor and connector for any damage and repair as necessary. If there is no visible damage, and you have access to a scope, you could check the CKP 5 Volt square wave pattern. If you do not, then, obtain a resistance reading of your crank sensor from a repair manualmag-glass_10x10.gif. (There are so many different types of crank sensors that there's no way to put here which resistance reading is correct). Then check the resistance of the CKP sensor by disconnecting the sensor and measuring resistance of the sensor. (It is best to check resistance readings from the PCM connector. This rules out any wiring problems from the start. But it does require some mechanical skill and shouldn't be performed if you\'re not familiar with automobile electrical systems). Is the sensor within resistance specs?
  3. If not, replace the CKP sensor. If so, recheck resistance reading from the PCM connector. Is the reading still okay?
  4. If not, repair open or short in the wiring to the crank sensor and re-check. If the reading is okay, the problem is intermittent or the PCM may be at fault. Try reconnecting and checking for RPM signal again. If there is now an RPM signal, wiggle test the wiring harness to try and induce the fault.
Sep 10, 2011 | 2004 Nissan Altima
WHAT DOSE THE CODE P0335 AND P0315 MEAN
CODE PO335 CRANKSHAFT POSITION SENSOR CIRCUIT. CODE PO315 - NO CRANKSHAFT POSITION SENSOR LEARNED. POSSIBLE CAUSES, CRANKSHAFT TONE WHEEL FLEX PLATE IS DAMAGED, TONE WHEEL PULSE RING MAY BE DAMAGED, ERRATIC CKP SENSOR SIGNALS WIRING CONNECTOR PROBLEM, CKP SENSOR HAS FAILED, PCM HAS FAILED.
Jul 01, 2011 | 2009 Chrysler Sebring
Codes read PO335, PO304, PO336 i need to know what they are for, Please !!
304 is misfire on cylinder #4. #4 is the middle cylinder on the driver's side.
The other 2 relate to the crankshaft sensor:
P0335 Crankshaft position (CKP) sensor -
possible causes: circuit malfunction Wiring, CKP sensor, ECM
P0336 Crankshaft position (CKP) sensor - range/performance problem
possible causes: insecure sensor/rotor, air gap, wiring, CKP sensor
Is the car running? If yes, check for a loose connector on the crank sensor. You may need to take the connector off and see if there is any corrosion on the terminals. If yes, do your best to clean with a small screwdriver and/or electrical parts cleaner.
From what I can tell, the sensor is on the bottom of the engine near the idler arm, but it has a long pigtail such that the connector is on top of the engine by the fuel rail. See pictures below.
for the misfire,
Please see my tip at http://www.fixya.com/cars/r6715318-causes_gasoline_engine_misfires . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Dec 18, 2010 | 1998 Cadillac Catera
Dodge durango PO320 + PO700 + PO725
SYMPTOM
P0320 - NO CRANK REFERENCE SIGNAL AT PCM
WHEN MONITORED
With the ignition ON.
SET CONDITION
No signal from the Crankshaft Position Sensor is present during engine cranking, and at least 3 Camshaft Position Sensor signals have occurred.
POSSIBLE CAUSES
SYMPTOM
P0700 - EATX CONTROLLER DTC PRESENT
WHEN MONITORED
Ignition key ON, Continuously.
SET CONDITION
Any DTC sets in the Transmission Control Module.
POSSIBLE CAUSES
Jun 04, 2009 | 1997 Dodge Caravan
2010 Nissan Frontier Crankshaft Position Sensor Standard Logo
Top Standard Crankshaft Position Sensor Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Standard Crankshaft Position Sensor Vehicle Part and Accessory Expert? Answer questions, earn points and help others
