Hitachi 16sf-160hj beat wave washing machine error f9
F9 signal occur and washing step hold before rinse sequence
kevin000
  • 1847 Answers
SOURCE: Simpson Esprit 750 Washing Machine.
the control panel has gone bad needs replacement.
Posted on Jul 15, 2008
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
  • 1531 Answers
SOURCE: Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Posted on Jan 31, 2010
jsrock516
  • 5911 Answers
SOURCE: what is a f9 error?
"F09" is an Overflow Condition error. The following link explains how to diagnose the problem yourself:
http://www.fixya.com/support/r3608557-f09_error_code
Read through the information provided and check all the common sense things that you can easily eliminate, first. For more in-depth troubleshooting procedures, refer to the tech sheet that came with your washer. The tech sheet is located inside your appliance. To access, remove the lower toe panel under the door by removing the screws under the bottom front edge (you may have to prop the two front feet of the washer up for better access - a 2x4 works well for this). With the screws removed, the panel will drop down, then come off.
The tech sheet will either be located directly behind the toe panel, or affixed to one of the interior cabinet walls. The tech sheet includes troubleshooting tips, error code definitions, test points, diagnostics procedures and wiring diagrams. You will need to use the tech sheet to accurately locate and perform some of the steps I have outlined.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Posted on Mar 24, 2010
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Posted on Dec 19, 2010
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
Hitachie washing machine SF-95CJ. without completing the
Owner's manual? trouble shooting? Should have errore codes
No manual? try http://www.manualslib.com/
Mar 08, 2015 | Washing Machines
Washing machnie hitachi sf 100 fjx displaying F9 during rinse
hitachi washing meching not worjing display f9
May 02, 2012 | GE Washing Machine
Model:SF-95CJ F9 FAULT CODE
my hitachi model SF-95 CJ is washing machine show F6 ,C4, F4 FAULT CODEcleck
Feb 11, 2012 | Washing Machines
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Jul 29, 2010 | Washing Machines
Hi i have hitachi SF-110CJ waching machine how can i cotrol the water temperature before starting the waching process
i have an error code f9 and washing machine stop spinning and dont turn , how can i fix it and where can I buy spar parts , i am from lebanon , west bekaa
Jan 19, 2010 | LWScientific LW Scientific Variable-Temp...
AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Aug 18, 2008 | Washing Machines
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
