Question about Reebok 8000 C Treadmill
Manual The display is not working properly bottom of numbers not showing and now the calories counter is not working correctly numbers going up to fast how to fix this thanks
    Top Expert:
  • Reebok Master
  • 12,223 Answers
Download it from www.fitness.manualsonline.com or from reebook
However you must adjust THE REED switch, see the diagram , clean it, test for open or faulty, and tight , clean the connector very well.
Posted on Jul 11, 2013
NORDICTRACK X9I CALORIE COUNTER IS WRONG
Yes the repairmen is o.k when he says the controllers nothing to do with the calorie counter.
See the block diagram attached, the problem is the display board or upper board. However adjust the REED switch, test for open or faulty, clean it, and tigh very well the connector b) tight the ribbon cable for keypads inside the display board. c) replace batteries from display by new one, with the same polarity, same markay such hybrid rayovac. c) clean the contacts battery.
God bless you
Jan 08, 2013 | Nordic Track Treadmill Motor Controller...
How do you winterize Model GE20P06SAG? There is no drain at the very bottom...?
Thank you for including model number for EZ identification of water heater
To drain tank without drain valve: Remove TP valve at top of tank and siphon out the water. Then reinstall with correct pipe configuration shown in product manual.
Product manual shows drain valve is not supplied with this unit.
http://waterheatertimer.org/pdf/GE20P06SAG-under-counter.pdf
Product manual shows the Installer should add both shut off valve and drain valve on cold water inlet line.
http://waterheatertimer.org/images/GE20P06SAG-under-counter-60.jpg
More resources:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Sep 30, 2012 | RELIANCE 19.9 Gallon Electric Compact...
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    I don't knowhow to get the electronic calories counter to begin registering once I begin exercising
    Have you tried the unit manual operation? The calorie and time feature should work without you plugging in age or weight. Now if the time is working .but calories fail then you have a upper console problem, if both are not registering most likely then it is a sensor problem. Not knowing what type of unit you have can't exactly to pin point components. But this a good starting point. Good Luck!
    Mar 23, 2010 | Exercise & Fitness
    The Reebok Fitwatch 10S Calorie Counter
    Yes when you are in time mode press the mode button 5 times this will be your calorie screen press the st/stp button to activate the calorie counter you will see in the bottom left corner it says CA ( meaning calories) and in the bottom right crn are the calories you are burning press the st/stp button again to stop then reset when you want to start again.Hope this helps can you help me? I keep pressing the sensor buttons and my heart rate does not appear what am I doing wrong ? Ive read my instructios inside out even returned the watch and got another but the same thing keeps happening ! Initial when I set the watch up it works then I just cant seem to get my heart rate to appear ????????? Thanks Nicole
    Mar 24, 2009 | Reebok Fit Watch 10M Strapless Heart Rate...
    How accurate are the calorie counters on treadmills and cardio equipment?
    Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
    Dec 01, 2008 | Endurance TF3i Folding Treadmill
    Reebok 8000 C Treadmill Logo
    55 people viewed this question
    Top Reebok Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
