Question about Philips HTS3306/F7 Home Theater
My philips hts3306/f7 home theater system wont power on how to fix it ?
I was listening to pandora and the whole system cut off by itself..i tried to power it back on and it didnt could it be a blown fuse
pgh_pa_guy
  • 2992 Answers
SOURCE: Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Posted on Jan 28, 2009
  • 15 Answers
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Posted on Jun 02, 2009
SOURCE: Home Theater philips HTS3372D/F7 change for regio Free
Turn on the player
With the tray open press:
99990 on the remote
Region 0 will appear on the bottom left of the screen ]
from http://www.videohelp.com/dvdhacks
Posted on Aug 21, 2010
Moe66
  • 13 Answers
SOURCE: I need pinout assignments for a Philips 5.1 Home
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Posted on Feb 04, 2011
SOURCE: I have a Philips Home
try actualize the firmware..go to http://www.p4c.philips.com/cgi-bin/dcbint/eula.pl?slg=ESP&ctn=HTS3051BV/F7&dct=FUS&link=http://download.p4c.philips.com/files/h/hts3051bv_f7/hts3051bv_f7_fus_aen.zip ....
1. Extract the .bin file from the zip file downloaded from this site.
2. Burn the *.bin file to the root directory of a blank CD. Make sure the CD burner is set to
finalize the CD.
3. To select Disc upgrade, press the menu button on the remote. Select Settings\Advanced
Setup\Others\Software Upgrade\Disc upgrade.
4. Use the cursor up/down button to select "Yes", and then press OK. The Disc tray will open
automatically.
5. Insert the Disc. Close the Disc tray.
6. After the disc has loaded, a confirmation message will appear. Select "Yes" and press OK to
start uploading.
7. After the disc update is finished, the unit will shutoff and eject the disc. Do not unplug or
turn the unit off while the software upgrade is in progress.
SW Version Problem resolved
1.005 - The Dolby Pro Logic feature does not function when
Dolby digital two channel audio is the source using
SPDIF (Digital Audio In) input.
1.006 - Unit shuts off after 30 minutes. Do not use the
Network upgrade to this fix this problem.
source philips.com
Posted on Mar 23, 2011
Hay I am locking for Regoin free code for HTS 3306 please
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
May 03, 2016 | Philips HTS3306 Blu-ray Home Theater...
How do I get my CSS21338/F7 to stop turning off
Try Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 06, 2015 | Philips SoundBar DVD Home Theater with...
Philips hts3306/f7, i have hooked up through ethernet port and it keeps cutting out beause of poor quility. how
Perhaps it would be worth trying a different Ethernet cable. Also try a different port on the router in case the jack has a physical problem.
Dec 12, 2014 | Computers & Internet
Philips hts3306/f7 wont power on
Check that the power cord is snug in the back of the unit and into the wall. Also verify that the outlet has power leading to it (by plugging something else in that you know works). If there is no power to the outlet you could have blown a breaker. Check your breaker panel and reset. If all those checks fail it could be an internal fuse or bad board. You'll need to bring it to a repair shop in that case unless you're familiar with troubleshooting electronics.
Jul 10, 2013 | Cars & Trucks
Unlock region on Philips HTS 3541/F7?
Unlock code for Philips HTS3541
1. Press Home
2. Press on R/C 8 6 8 9 3 1 0 (the 0 being multi-region)
Sep 13, 2012 | Philips HTS3541/F7 - 5.1-Channel Blu-ray...
Turn on the player
99990 on the remote
Mar 20, 2010 | Philips Audio Players & Recorders
Philips HTS3306/F7 Home Theater Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
