AC furnace huming
Home AC furnace hums. Las tweak it wasn't working but still humming. 7 days later I works fine but it still hums. What coil be the problem from it working intermittently ? P.S. last week It did blow a 3 amp fuse but even after I replaced it it took a week for I to work again.
Blower motor & or capacitor bad
Posted on Jul 11, 2013
  • angel Jul 12, 2013
    Thx. Replaced capacitor. ... Tah dah. It works now.
    Awesome!
3 Suggested Answers
  • 182 Answers
SOURCE: Goodman Furnace/AC unit not working
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Posted on Jul 04, 2008
kingbrizzle
  • 407 Answers
SOURCE: 3 amp fuse blows when ac is switched on. Heater works fine.
There is a short in the low voltage wires somewhere for sure. The most common place is the low voltage on the outside unit, sometimes animals chew through them or they get cut with a weed eater. Just my experience. You basically have to trace it back all the way to the thermostat and heater. The only other thing is the contactor
Posted on Jul 01, 2012
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
I took my 2002 Ford Windstar LX 3.8L to a Ford Dealership to have three recalls fixed. My brakes, rear axle, sub-frame brackets. When I got it back it has a loud humming when I pick up speed from any
a hum is a very vague request a hum can be from tires ,engine ,driveshafts rear or front axles etc advise to bring back to dealer who preformed work on vehicle and advise them that the hum wasnt their prior to repair work also the work should be under warranty
Jul 24, 2013 | Cars & Trucks
Pump stopped working
Reverse the wiring .put live to neutral and vise versa. May have been put wrong on label. Store wont tell you that because they will wan't payment to come out to your home.
Jun 21, 2013 | Pentair 340210 Dynamo Swimming Pool Pump...
I own a Bose Acoustimass 7. I noticed humming coming from bass more noticeable than before (although I recently moved it to another smaller room) I also noticed when I hear this humming- the higher I turn...
I was having this very same problem. I finally figured out that I was getting feedback to the system because my TV cable coming into the house wasn't grounded right.
Oct 04, 2011 | Bose Acoustimass 15 System
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Will not kick on at times.....
YOU MAY HAVE TO ADJUST THE INDUCER A HAIR!
Dec 10, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
171 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
