Question about Jl Audio 250/1 Car Audio Amplifier
Amp i am having trouble with my amp shutting off
  • brettl Sep 25, 2007
    not real smart when it comes to this but i'll give it a shot.two subs 10" jl w3's, also have pos. and neg. at 4 gauge, remote wire to head unit... prob 20 gauge? both speakers are wired together and was bridged to two ohms. amp worked great in another car. switched to this one and no longer worked. replaced the head unit and still does not work. continue to run cheaper junk amp for power to subs and it works great. one thing though, the speakers sound like they may be blown now. could this affect the jl amp that is shutting off?
  • 752 Answers
Need ALOT more info! How many subs? Are they in parallel or series? What kind of wire is it hooked up on? And to where? What are the settings set to? and so on....
Posted on Sep 22, 2007
Why does my1992 Toyota Previa keep shutting off & stalling?
Possibly, but you could also suspect the computer-controlled idle valve or motor, the throttle position sensor, or a weak fuel pump.
It might help you to check for any trouble codes in the computer. The check engine light is used to flash out 2 digit trouble codes; here's how to do so, with a list and description of codes:
http://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995.
Apr 10, 2014 | 1992 Toyota Previa
When I turn it on it shuts off amp
Pete,
This sounds like a wiring issue. I don't know what you're turning on that it causing the amp to shut off - because you didn't include that info. Double check the installation instructions of both the amp and the other device. Make sure you're connecting to valid points in the car's wiring. If you're still having trouble, please provide the year, make and model car and the make and model of the amp and the other device. Has either worked in the car alone before - or did you install them both at the same time? Are these devices new, or used. Did you see them work correctly before? Thanks!
Nov 06, 2013 | Car Audio & Video
Vostro 200 PC freezes on Dell Start up page & won't turn on
If you have windows 7 installed, then see if you can boot to the DVD and run a repair on the OS. You also may want to run a diagnostics on the system if you can get to the F12 menu
Feb 27, 2010 | Dell Vostro 200 PC Desktop
My 2009 Dodge Ram has trouble starting &
you need to find out what code is in the computer. There are several things that can cause your problem. Auto Zone will scan your computer for free to get the codes out if you can keep it running. Isn't it under warranty?
Feb 07, 2010 | 2009 Dodge Ram Pickup 1500
I have been having trouble with my car stereo system
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Aduz
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
Shutdown
There is either a thermal problem in the amp itself (a bad part) causing it to shut down after a while, or the amp is overheating due to a load problem. This may be due to wiring issues or a bad speaker. Try running the amp into a set of test speakers connected directly to the outputs with all the other speaker wiring disconnected. If the amp still shuts down you'll know the problem is in the amp itself. If it runs OK, you'll have isolated the trouble to the wiring or speakers and can test that portion.
Dec 10, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp shuts off
check your remote wire and check your power and ground, clean all connections with a contact cleaner/rejuvinator (ridox/deoxit).. many times the thin remote wire will develop breaks or conductivity issues over time, i have replaced many of these just in the last few months.
to make sure this is the problem, remove the remote wire and temporarily jump the power wire to power and remote, the amp will always be on at this point, but it should help you diagnose whether the remote wire is the problem or if it is an amp or cabling issue.
hope this helps,
trin
Nov 07, 2007 | Kenwood KAC-X520 Car Audio Amplifier
Power Problem, LED Lights up and then shuts off
Do you have the switch or activate wire on the new amp. to the right hookup? If you do, then theres a problem with the amp and if your not a tech these can be a difficult thing to trouble shoot. Take back the amp or seek out a pro to test it on a bench. Good Luck
Jul 24, 2006 | American Pro VS1405 Car Audio Amplifier
Jl Audio 250/1 Car Audio Amplifier Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
