Question about Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator
Water leaks when icemaker full
This has happened twice in past 2 months in this 4 year old Samsung. Water comes out from the water filter while it is screwed in. The icemaker was full both times this happened. Never had a problem before. First time I took out the filter and out of paranoia I didn't put one in until last week- new filter, locked and secure in place. WELL, sure enough...the ice maker filled up (I didnt turn the ice function off) then one morning i came out to a flooded kitchen. Now the freezer won't get belo 4 degrees F; I took the filter out and the leak stopped. I am stumped-- is this a filter issue (what is likelihood that both filters were faulty?) or some sort of cut off or ice maker problem? Now the freezer isnt getting to temp so maybe the water damaged something there? Add to it there is only ONE authorized servicer in town -- I am talking multiple city area-- and they haven't yet called me back after 3 days. I dont think I'll be getting a samsung again. These days it seems nothing is built to last. the avocado fridge and gold freezer my parents had worked for DECADES with no problems at all, ever! And yes they had icemaker so hey. they used to work fine :)
  • Samsung Master
  • 16,026 Answers
Replace the icemaker
Posted on Jul 10, 2013
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: freezer stopped working
Solomonau, it's hard to tell without being there exactly what is going on. I do know however,that in April of 2005 Samsung came out with a bullitin regarding the cap tube. It states that it has been inserted into the dryer incorrectly and can cause no cool situations. This is part of the sealed system which should be covered for 5 years. What you are describing sounds like a partial restriction, which could be taking place in that dryer and cap tube. If you were to post your model number, I would be able to tell if yours was included in this bullitin. You can then contact Samsung and inquire about this service bullitin, Catriver..post back.
Posted on Sep 20, 2006
TJBENGR
  • 121 Answers
SOURCE: Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Posted on Apr 21, 2008
TJBENGR
  • 121 Answers
SOURCE: Ice maker hooked up for the first time doesn't work.
Hi, The storage is usually on the back fridge wall near bottom. Your answer indicates the demand solenoid is not operating. You will need to check wiring connection at the solenoid, and at the ice maker plug. Best of luck.
Posted on Apr 27, 2008
Rsg257 imaker bucketstuck
Probably indicates a leak inside the ice maker that froze the bucket to the icemaker outer shell. Our Samsung (under warranty) has had the ice maker components replaced twice in under a year for internal leaks (I think the 2nd repair has finally solved the problem - it leaked from the beginning, we had service out after 4 months, it continued to leak, and we had service out again a few months later).
First time, the tech had to take a blow dryer to melt some of the ice that had built up inside the unit, to free the bucket, so he could replace the components.
CAUTION: water contacting a blow dryer can cause an electrical short and personal injury. Be VERY careful if you resort to that method to melt the ice, and be sure to put towels under the ice chute to catch water. Also be sure not to use too hot a setting so the ice maker plastic doesn't become deformed. When in doubt, call for professional service.
Aug 27, 2014 | Samsung RSG257AARS (241 cu ft) Side by...
Water & ice in bottom of freezer
Sounds like there is a damaged water line that is leaking into the freezer.
Aug 02, 2017 | GE Refrigerators
Fridge leaking water
The drain line may be misdirecting the defrost water so that it misses the pan or the pan may be damaged or mispositioned.
Dec 03, 2013 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Bosch 125fx heater barely heats water
1) Recommend replacing tankless with ordinary tank-type gas water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://hometips.me/Mar/Which-is-best-gas-water-heater.pdf
2) Tankless cannot be exposed to more than 11 grains hardness in water or unit will fail within 2-5 years. Water softener is required.
http://hometips.me/Tls/Battelle_Water-softening-research.pdf
3) Descaling tankless water heater each year will not restore functionality, or restore efficiency of tankless, nor restore full efficiency to tank-type gas water heater.
4) Bradford White side-by-side testing research comparing their tankless with their tank-type shows that tankless will save $1-8 per month on energy bill vrs ordianry tank-type ....but conclude that tankless 'fall far short of payback' due to maintenance, repair, installation and replacement costs.
Study compared full cost, and not just monthly energy bill, since All costs are energy.
Feb 16, 2013 | Water Heaters
Water collecting under Cool Select pantry. 3 servicemen attempted to fix it--to no avail. Now water is frozen at front of pantry and still pooled in back. Refrigerator is less than 2 years old. ALSO, a...
Do you have an automatic ice maker/dispenser? If yes check and/or replace same, and also checkfor broken pipes. you may have to slide out fridge to do so....be careful as piping or wiring my also be tangled. look for leaks.Repair as may be necessary. You might also take offthe filter,be sure water is shut off, inject food coloring into the water line,reconnect everything and partially open water and look for colored water which should lead to the leak.
No icemaker? orven as last resort with icemaker, check for hidden built up frost, sometimes a tricky deal and/or turn off fridge completely and let it come to room temp (defrost the whole thing) and see what happens. A collection of new water will inticate that it was over frosted. Probably from too many door openings and closings. Be prepared with cleanup sponges and such! Note: store food properly while defrosting!
Feb 10, 2011 | Refrigerators
My 4 1/2 year old Bosch dishwasher won't clean.
this tells me that you have a drainage problem chk. the hose for kinks and or plugs
Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Water gets to filter but not anywhere else
your water line that goes past the filter is clogged. use compressed air to flush out
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
RS2630SH icemaker slow production
Had the same problem. This allows 12 seconds for the tray to fill. If your water filter is the least bit dirty or the water supply line is clogged a bit, you will get an incomplete fill and the cubes will be hollow, mishapen, or, in my case, all won't eject properly. Replace your filter. If that doesn't do it then use a shop vac with any kind of modification to it that will fit into the supply line and **** out the blockages. Hope this helps.
May 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
119 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
