Question about Gateway Tablets & eReaders
Usb ports not working - Gateway Tablets & eReaders
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Charging port not working. How can I fix it
If it's a mini-USB charging port you could have damaged contacts on either your USB cable or the USB port itself. You should try another cable first hoping that it's only a damaged cable. If the new cable doesn't do it then it's probably the USB port itself. If that's the case, you probably have to take or send it in for repair.
Jul 28, 2015 | Tablets & eReaders
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
I have an irulu 7" tablet that I got for Christmas. So far the tablet is working, however the keyboard case does not work when plugged into the USB port at the top of the tablet. It is my understanding...
Not sure on you particular model but most tablets have 2 mini USB ports one has a power supply and the other is just an I.O port .
Try your keyboard in the other port if you have one and it should work. If not it may be faulty.
HTH
Jan 01, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
Power port needs repaired
Are you sure it is the port that needs fixed, or is it your usb cord you plug into? If it is the port you need to send the tablet in for a technition to repair. First try a new charger or usb cord and see if it works.
Feb 23, 2014 | Android Ainol Novo 7 Paladin Tablet PC
When i plug in my velocity cruz reader into the usb port it tells me that the USB Device Not Recognized?????
Chances are the reader is defective. Try to plug it into another computer to confirm this. If it works try another USB device to confirm that the port is working.
Jul 21, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
Tablets & eReaders Logo
18 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
