Question about Frigidaire Affinity ATF6000F Front Load Washer
Atf6000fs1 Buzzes and won't lock when I press start
  • Official Brand Answer
  • 4,342 Answers
Hello Michael - Thank you for your post! Let's try resetting the washer. This can be done by either unplugging it or flipping the household circuit to the off position. It is important to wait roughly ten minutes and then turn on the unit. Will the door lock? If the issue persists, then more than likely the unit is experiencing a communication issue with the control board and the door latch or the washer has a faulty door latch/lock assembly. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Posted on Jul 11, 2013
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
When i turn it on, it buzzes and doesn't start
Sounds like the control board won't allow the motor to begin the cycle. Contact a professional for an accurate diagnosis.
Sep 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Dryer won't restart breakers ok door switch funtional but when i press srart button just buzzes......... suggestions?
Reach inside and try to turn the drum. If it is stiff you could have a bad roller or support bearing depending on your model. I have all kinds of dryer manuals HERE
and Here
Jul 07, 2012 | Dryers
Drier Shut off, won't restart. Is there a reset button?
What brand is the dryer and the model number off the machine would help greatly
May 21, 2012 | Dryers
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I own a maytag neptune washing machine. It was working o.k. and suddenly it won't start. I push the start button and it buzzes and shows a message that says,"It appears the door was not opened...
Hi Debi:
First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.
Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 06, 2011 | Maytag Neptune MAH7500A Front Load Washer
Whirlpool duet GHW9100LW won't start, won't give error code. No locking noise when trying to start, and makes a couple of clicks "in the back" when pressing start in troubleshoot mode. No...
Hi, I've only just come on line to see and glad that you have identified the problem yourself- as you say persistence pays. I'm not even sure that I would have been able to suggest anything myself other than 'are you sure the lock and sensor are physically working?' ;-0) John C
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore model # 86470810 buzzes when I press start but won't run
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch
Sep 21, 2011 | Kenmore Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
Frigidaire Affinity ATF6000F Front Load Washer Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
