Question about Dell Inspiron N4010 Notebook
Touchpad and buttons do not work
I have a Dell Inspiron N4010 Notebook whose touchpad and Left/Right buttons have stopped working. They will not move the cursor or function in any way. I checked that it was still enabled. I deleted the drivers in hopes that rebooting would reinstall. But Device manager doesn't register the touchpad and "Mouse" in control panel only sees the USB HID compliant mouse. I can use a USB mouse without difficulty. System I'm guessing there is a physical problem inside the computer but hoping there is a better answer. It may be my imagination, but the buttons feel a bit 'spongy' or something. Like maybe something was spilled on them.
  • 369 Answers
Press and hold the Fn key and then hit F3 key.
Press and hold the Fn key and then hit F6 key.
Install touchpad drivers from dell website.
Posted on Jul 11, 2013
  • 6771 Answers
SOURCE: My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
Posted on Apr 01, 2012
Roonie Tunes
  • 136 Answers
SOURCE: dead dell touchpad x(
Have you tried System Restore? If not familiar... Start Button ---> Help ---> System Restore ---> "Restore my computer to an earlier date" --> choose an appropriate date, maybe a few days earlier than the problem.
Re-boot and see if works! If you are ceratin that the problem arose simply from hibernating, then restoring should do the trick!
Hope this helps!
-- RT
PS - Don't forget to vote!
Posted on Sep 07, 2009
candyxss07
  • 4 Answers
SOURCE: Touchpad Sensitivity
Click on the start menu and select "Control Panel". Once in the control panel, select "Hardware and Sound". Once in the hardware and sound menu, click on "Mouse". Once the mouse menu comes up, there should be a tab labeled "Dell Touchpad". Click on that tab and then click on the large touchpad icon to take you to the touchpad options. Once in the touchpad options menu, click on "Device Select". Once you click on deivce select you should see the option to "enable" or "disable" the touchpad.
Posted on Mar 28, 2009
SOURCE: Mouse cursor moving by itself
I have the same dell computer, you have to down load the newest synaptics driver and disable the touch point mouse in the middle of the keyboard.
Here is the link.
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&qmp=12&p=1&subcat=dyd%2f17&rf=all&nk=t&sort=-date&snpsd=A&ira=False&spf=Latitude&ssysid=LAT_PNT_P3C_C610&ssysn=C510+%2f+C610&~srd=False&ipsys=False&advsrch=False&~ck=anav
Hope this helps!
It worked for me.
Posted on Feb 09, 2008
joecoolvette
  • 5660 Answers
SOURCE: My Dell Precision M6400 wouldn't keep a setting and now arrow
Go back into BIOS, and set that screen to Default Settings. Be sure to save your changes.
(F10, Y for yes, press the Enter key)
Posted on Aug 19, 2009
Touchpad zoom
You can download the user manual here: http://www.dell.com/support/Manuals/us/en/19/product/inspiron-14r. That should show you what you want.
Feb 09, 2014 | Dell Inspiron N4010 Notebook
My laptop Dell inspiron N4010 touch pad is not working.. wats the solution
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 11, 2012 | Computers & Internet
My dell inspiron n4020 touchpad wont work
Try pressing the button to the right of the F12 key - the touchpad enable/disable key
Dec 18, 2011 | Dell Inspiron N4020
My touchpad on my dell 1548 has stopped working
It could be you may need to reinstall the driver for your touchpad or the touchpad itself is bad
Nov 10, 2011 | Dell Inspiron 1545 15.6-Inch Laptop...
Dell Inspiron E1505 Buttons on mouse NOT RESPONDING, Left or right.
run your comp in safe mode, if still not working, run 32 bit dell diagnostic using teh drivers disc, test touchpad, if still not working replace palmrest
Feb 21, 2010 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 1525 touchpad not working properly
You can try the following steps.
1. Turn laptop off.
2. Remove all external devices and disconnect AC adapter power cable from the system.
3. Remove the battery from the system.
4.Hold down the power button continuously for at least 5 seconds. Do not release the power button during this process.
5.Insert the battery back to the system.
6.Power the laptop back on.
Try using touchpad again.
Dec 29, 2008 | Dell Inspiron 1525 Laptop Jet Black
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Dell Inspiron N4010 Notebook Logo
146 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
