My pioneer denp4200ub says that music is playing and no sound is coming out of the speakers.
4 Suggested Answers
  • 137 Answers
SOURCE: no sound
check the plug that goes directly to the altec box. or it could be the wire is the culprit..
Posted on May 09, 2008
Mr BrokRench
  • 1623 Answers
SOURCE: speakers are not working
sounds like your audio wizard has made google your default player. Try running the wizard with your media player and make the player the default device for your system.
Posted on May 06, 2009
  • 207 Answers
SOURCE: all speakers on x-530 pass test but no sound comes
Is the speaker system set up in Windows as a 5.1 speaker system? If so, the problem with the sound is the program used to play the audio. For example if you are watching a movie and the player used does not support 5.1 then it will not play the audio properly. If the sound works correctly playing a game in 5.1 you should be able to figure it out from there.
Posted on Mar 09, 2011
Plays only mono when listening to music
I lot could depend on how the music source has been connected to the receiver. If you are using a stereo CD player then you may need to check if it is configured to send audio in stereo mode and not mono. The input source selection for the audio is given in page 26 of the manual.
You can go to the setting menu in Receiver and configure the speakers settings according to which ones you have installed.
Also refer page 25 in the manual to over ride speaker configuration if it is not showing correct.
VSX 826 Pictures support downloads Pioneer Australia
Aug 22, 2014 | Pioneer Vsx 826 K Av Receiver Black
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Jun 24, 2009 | Pioneer Audio Players & Recorders
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
My pioneer sounds really bad
Check the antenna input...sometimes these come loose
Mar 12, 2009 | Car Audio & Video
When i play music cd all speakers work but when put a dvd on only the 2 front ones and centre speaker goes? Tried all settings. Y are my 2 surround sound speakers not working? I have a pioneer vsx-816...
What is happening is the the pioneer is set up so that you can choose how you listen to your DVDs. So first you must see how your DVD is connected via the audio. I am fairly sure that the Default on the Pioneer is to play it through the standard stereo if all you have plugged in is the left and right audio plugs. If you buy an optical cable or a plug in the Digital Coax out put to the pioneer receiver, then the pioneer will decode the sound and out put true surround sound. Some DVD players don't have a digital out put, but these are the cheapest ones out there. If yours doesn't have a digital out put, then you need to get one that does. They can be purchased for as little as 39.00.
Okay lets assume you bought a DVD player with Digital out put for audio and you have it connected to the receiver. Now, you have to change the mode on your pioneer to let it know that your audio is coming in DIgital when you select the DVD. (Though this may already be the case and you won't have to do anything once you connect it.)
Dec 08, 2008 | Pioneer Televison & Video
Controlling pioneer VSX-456 receiver.
Music is not in DTS or Pro Logic, that is why.
Jun 19, 2017 | Pioneer SX-315
No sound
Apr 08, 2008 | Altec Lansing VS4121 Computer Speakers
Mp3 player only plays on right side speakers
Have you tried a different jack? It could be faulty.
Aug 11, 2007 | Pioneer DEH-P6800MP CD Player
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
15 people viewed this question
 Grubhead
Grubhead
