Question about Craftsman Garden
Managemylife com sears can't get any spark on rider mower need expert help i've tried every thing i know
Was fine i got off to remove twig got on and it won't start no spark. removed green ground still no spark. on either plug. seems unlikely both magnitos would go bad at the same time.
    Problem Solver:
  • 17 Answers
You might have snapped the key on the crank shaft.Did you hit anything on the ground?The KEY protects your engine from ruining it.Take the top off and see if the key is still in the groove from the crank.If it is not bent,or is bent.Thats your problem.It will never get spark,and never start.Cost $3.00/Hope this solves your mystery.If not check coil.
Posted on Dec 05, 2013
SOURCE: Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Posted on May 27, 2009
  • 62 Answers
SOURCE: I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Posted on Sep 25, 2009
Testimonial: "This is exactly what I did and found the clutch safety switch was sticking closed.Thanks a lot for your suggestion and help."
emissionwiz
  • 75797 Answers
SOURCE: sears craftsman rider mower model #917.276815 will
WHAT U NEED TO DO IS GET A CAN OF SPRAY STARTING FLUID (ANY AUTO PARTS STORE, VERY CHEAP) AND SPRAY IT INTO THE AIR INTAKE OF THE ENGINE, CHANGING THE SPARK PLUG ISN'T GOING TO HELP HERE, SPRAY THE STARTING FLUID AND ONCE IT IS RUNNING THE PROBLEM WILL CLEAR UP MOST LIKELY.
Posted on Apr 05, 2010
  • 130 Answers
SOURCE: I have a Sears GT
I'm going to throw this quick one at you but there are several problems that can stop the spark reaching the plug. Check the connection at the seat switch. The "connector" has a built in switch in addition to the switch that it plugs into. This is designed to prevent people from unplugging the connector and installing a jumper wire to bypass the seat switch. If this is not making proper connection it will kill the spark. You may also check the pluger switch for the seat as well. Hope this gets you in the right direction.
Posted on Feb 18, 2011
philwalker78
  • 605 Answers
SOURCE: Rider loses power after mowing for 30 - 45
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Posted on Jun 01, 2011
I need the blade belt routing for dys 4500 42" cut
Mike, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
craftsman dys 4500 belt diagram Google Search
Replacement Parts Accessories Sears PartsDirect
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0701547.pdf
EASY CRAFTSMAN DECK BELT INSTALLATION
May 07, 2016 | Sears Garden
What do I need to be able to use my Snowblower attachment Craftsman 2 stage blower 486.24839 933 on my Craftsman Riding lawnmower YTS 3000
Michael Brady,
Here is a customer contact reference for your records. For help and evolvement. Sears Customer Phone Number Shortest Wait Best Support .
Here is a review and site you can navigate for your decision Craftsman Dual Stage Snow Blower Tractor Attachment .
This second link shows a Husqvarna as an option to your rider Sears com. If it does not apply. The following will guide you to success
I have best results in the past by utilizing this link Craftsman Riding Mower Tractor Parts Repair Parts . Repair help and ask an expert in their arena.
Open any manual, there, are options for contact and assistance. Here is a phone number in the meantime for customer service 1-800-252-1698. You will see this example.
Fare well
Sep 30, 2014 | Craftsman Garden
The lock nut is just that, a lock nut. After you remove it the bolt may have to be unbolted. Give it a shot. GOOD LUCK FRIEND.
Sep 05, 2014 | Garden
I have a model 113.29991 old table saw... need new miter gauge... new ones do not fit the width of the slot on the steel table top. where can I find a new gauge???
Craftsman is a Sears brand. Do you have a local Sears store?? They should be able to help you.. If you don't have a Sears or a K-Mart, you can get on the internet and find an outlet for tool repair parts. That's how I find my lawn mower parts...
Dec 03, 2013 | managemylife.com
I am looking a repair manual for vintage sears suburban lawntractor model #917.253130
try this and if it dont have what you need then try www.managemylife.com . they have manuals for all types of things on there ... hope this helps
Nov 07, 2011 | Garden
917271650 primary mower belt diagram
check under the foot rests and for a copy to print out write down model number and check out www.searspartsdirect.com or www.managemylife.com . both you can save the diagram you need and then print . manage my life will give you the whole manual for the rider including a complete parts break down in pdf format . hope this helps
Oct 24, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need a manual for a craftsman riding lawn mower model number 53627030t serial number 7557883511ac87
Use this link:
http://www.managemylife.com/mmh/owner_manuals/search?query=+536.270301
Left side choose "Get Manual" = owners manual
Clicking on your model number to the right = parts diagrams and lists at
www.sears.partsdirect.com
This should be your model number: (note the period after the 6)
536.270301
Direct manual download link:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L1001176.pdf
Thanks for choosing FixYa,
Kelly
Aug 21, 2011 | Craftsman Garden
Sears craftsman rider mower model #917.276815 will not start. ran out of gas and after re-fueling,would not start what to do? also don''t know how to change the spark plug inthat unit - can''t find it
Apr 05, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
26 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
