Question about HP LaserJet 3050 All-In-One Printer
Failed hresult error
I am trying to run a software called djuice friend finder-a chatting software. it was running fine on my old computer. Now when i changed the system and tried to run it it gives me error FAILED(hresult). Whats the reason and how can i fix?
Please reply soon.
Thanks
  • Najaf Azad Apr 24, 2009
    same FAILED(hresult) error on my PIII
    I have same problem FAILED (hresult)....
    Some knows the solution...please post....!
Same prob faild hresult
Posted on Sep 19, 2012
SOURCE: Ink System Failure
I myself have not tried this, but apparently it came from HP.
HP Photosmart C5180 show ink system failure message
This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :)
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
Posted on Apr 22, 2008
SOURCE: Fatal error installing HP 3055 all in one
The reason for the failure to register hpbmiapi.dll is a missing registration of ATL.DLL.
1.) make sure that ATL.DLL exists in the WINDOWS\SYSTEM32 directory,
2.) in the start menu select run and enter: "regsvr32 c:\windows\system32\atl.dll"
Retry the installation process of the HP 3055 printer.
This worked perfectly for me.
Posted on Jul 09, 2008
  • 352 Answers
SOURCE: Ink system has Failed. Error: Oxc18a0306. Please Help.
Try updating printer drivers:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 12, 2008
  • 47 Answers
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Posted on Nov 22, 2008
SOURCE: HP C4580 PhotoSmart Install Crash
My photosmart all in one printer C4400 does not turn on. I have tested all connections. It still does not turn on.
Posted on Apr 14, 2009
Hp l1906 desktop error
you must go to www8.hp.com and get full support via ONLINE chat, or download the diagnostic software from them.
God bless you
Jul 18, 2013 | Computers & Internet
Strugling to download program
Post your OS, Service Pack if applicable. Have you done ALL your Windows Updates? Take a look at this procedure: http://digita7seven.blogspot.com/2012/11/how-to-fix-error-hresult-0xc8000222-net.html
Apr 01, 2013 | Nuance PDF Converter Pro 8 Windows...
Many errors after installing a new HDD on samsung R480 laptop
HI , there ,
Did you back up your data ? if so just recconect your old hard drive if you didnt format it and run windows go to my computer right click and click properties scroll down the the bottom and you should be able to see your product key jot that down and reconnect your new hard drive install windows and enter the product key.
as for the windows updates look up the error messages , you might have to copy the folder and delete the old oneas sometimes the donwload folderr gets corrupt.
Hope this helps .
Dec 29, 2012 | Samsung R480 Notebook
I have problems signing in to Djuice Friend Finder messenger for PC. It was working fine until I installed new operating system and now it gives error failed(hResult every time I try to sign in. Please...
You have to download the messenger again and reinstall it but make sure that you have remove everything from the previous messenger.
Good Luck!
Mar 04, 2011 | Computers & Internet
When installing MC9 on my Vista machine I get the following "Error 1904.Module C:Program Files (x86)MasterCook 9ProgramMCWrap.dll failed to register. HRESULT -2147220473. Contact your support personnel."
Are you installing as administrator?
you could try:
Start->run
and type in the following line
regsvr32 "C:Program Files (x86)MasterCook 9ProgramMCWrap.dll"
or wherever the .dll path was
then try reinsalling.
When I installed it, I right clicked on the install file, and clicked RUN AS ADMINISTRATOR.
Try reading this:
mc6help.tripod.com/mastercook_and_vista.htm
Sep 17, 2009 | ValuSoft MasterCook Deluxe 9.0: Windows
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Run the dell diagnostics on the sound card .
1. Restart your computer
2. tap on the f12 key slowly five times
3. select the option Boot to utility partision or diagnostics
4.select dell 32 bit diagnostics
5. Select customer test and test sound
If the test pass, try system restore , probably the problem is with the sound card drivers
if the sound test fails , shutdown the system again and remove the cmos battery and start the system without it once.Check sound again .
Thanks
proton
Apr 28, 2009 | Creative Labs SoundBlaster Audigy 2 ZS...
Computer crashes event 52
Hi Sharon21,
As Microsoft says this problem occurs when the Patch UI Monitor component tries to call the client user interface (UI) when no user is logged on.
You can download hotfix available on the Microsoft site.
Run the SMS2003-RTM-KB831648-X86-ENU.exe update file, and then follow the instructions in the wizard.
Regards
ELLIN
Sep 17, 2008 | Microsoft Windows XP Professional With...
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
1,117 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
