Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
Toro zero turn mower eletric blade engagement
Have a comerical grade toro titan mower mower blade turn fine for about 15 mins then disengagees after the mower sits and cools the mower will engage again what is causiong this?
carolinabeck
SOURCE: my toro mower disingages the blades after it runs for awhile
ik ben carolina beckers en ik heb met jaak coppens iets gaan drinken
Posted on Aug 08, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
mickey813
  • 472 Answers
SOURCE: toro groundmaster 120 model 30612
you may put a wire frome the moter to the fram see if that helps let me know
Posted on Oct 15, 2009
SOURCE: i have 42in toro zero turn. turn the key to crank
i have a torro zero turm cant get the stater to engage replace starter, relay swithch and starter solevoid
Posted on Apr 12, 2012
  • 6468 Answers
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Blades won't engage on my toro ss 5000 zero turn mower
for any ride on machine that the blades don't engage id start at looking at occupancy seat switch , these are most times the culprits then if that's ok I move on to the actual engage switch and then on to clutch as last element
don't forget that past 2013 mfg machines operator must be in seat and weight over 80 lbs , the clutch pedal must be depressed and transmission not in reverse to engage the blades on a consumer grade lawn tractor (thank the CSB for that )
Aug 27, 2015 | Toro Garden
Toro zero turn starts fine and stalls as soon as I disengage brake
Sounds like the seat switch is not reading you are in the seat. Without a wiring diagram, it is difficult to say exactly.
May 30, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Dec 26, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
The cutting deck on my toro zero turn won't
Is something Jammed into the Blade?
Apr 14, 2013 | Garden
Toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
192 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
