Question about Dryers
I want to instal a dryer ( gas) in my kitchen, the only way is to used the gas line from behind the stove, now how do I do it? And what do I need to do it? Thank you for any good advice.
    New Friend:
  • 109 Answers
You for one need a licenced gas person other wise no insurance
Posted on Jul 10, 2013
4 Suggested Answers
  • 105 Answers
SOURCE: I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Posted on Feb 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: no heat from kitchen aid gas dryer model
Most gas dryers have a flap under the door. The flap has spring clips up top that are easily compressed by a putty knife. You can then remove that kickplate and get to the problem. Here is a few repair pictures:
HERE
Bonus Look around for other nuggets of knowledge. If you need a manual HERE
Posted on Dec 30, 2009
  • 22 Answers
SOURCE: LG Tron Gas Dryer Model # DLG8388WM - I bought a used LG Tron and have to convert it to LP from Propane. What parts do I need and how do I do the install myself. Thank You.
Here's the oriface to convert it to Natural gas:
http://www.appliancepartspros.com/section-3-parts-for-lg-dlg8388wm-abweeus.html
Part # M170 is for Natural gas, you have a #M171 in there now for Propane.
$5.57+ S&H
Here's the manual to do the conversion:
http://www.appliancefactoryparts.com/content/pdfs/125536.pdf
Real page 32, pdf page 32.
**** Be SURE you back the gas valve screw out as shown or soot city in your tube!!!
You can pay a service tech like myself $90/hr, 1 hour minimum charge to do the conversion in 5-10 minutes, or do it yourself in 10-15 minutes with a #2 philips screw driver, a straight slot screw driver and a crescent wrench. Your choice! :) Hope this helps you.
Posted on Apr 09, 2013
Tick noise gas line from gas dryer up to kitchen stove
sounds as if you igniter is trying to continually lite not sure about how flame senser works on that model but normaly senser is right next to flame may have been bent away from flame I am use to older models
Feb 07, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Westinghouse oven no gas but supply and power is good
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Jan 12, 2013 | Westinghouse WGQ332HS 5.7 cu. ft. Gas...
We have an old O'Keefe and Merritt stove in a
on most stoves where gas line connects around back should be a gas shut off valve if none put one on
Jun 06, 2017 | Kitchen Ranges
I have a LG model# DLGX2502V gas dryer and I want to convert this dryer to LP. Need to know where to locate gas valve and how to get to it. Also steps to take to do this. I have already purchased the...
I'm surprised they didn't give you instructions with the kit. Gas vale usually at floor level behind dryer. Sometimes you have to remove the lower drawer in stove it there is one and reach through there to turn off valve. After you pull the stove out I would remove the flex line and put a good plug on the valve..
Sep 22, 2010 | Dryers
I have a galaxy gas range says it is set up for gas or propane how do i switch it and is it expensive
The cost of the parts is low. Many ranges have the conversion kit attached to the back of the unit. (If installed, pull the range away from the wall and then check the back. Another likely spot is behind the storage drawer.) If the parts aren't provided, then check your manual for information on ordering the conversion kit. (At least one range I've researched had a price under $20 for the conversion kit.)
The biggest cost is to get a licensed installer to do the conversion. This is required to maintain the warranty. It is also required by law in some states. Talk to your gas company (most appliance shops do not have staff that handle propane conversions).
The instructions are included with the conversion kit. It's fairly simple and takes a screwdriver, wrench and ratchet with correct sized socket (mine took a 10mm). A nutdriver can be helpful. Check your instructions for any other tools you need. With the stove unplugged and disconnected from the gas supply, turn over the LP/NG part in the regulator (do not remove the entire regulator). Adjust the air flow damper. Remove the current orifices for both the range and the stovetop. For best results do these one at a time (the orifices are labeled and are for specific locations). In the oven, you need to remove a few covers to reach the various dampers and orifices.
Then connect the stove back to the incoming gas line and power supply (use a new flexible gas line for the connection to the regulator). Check for leaks. Then you may need to adjust the flame for each of the inlets. The stovetop burners usually have a set screw behind the knob so turn on the flame and then remove the knob. The set screw takes a very small screwdriver.
I hope this helps.
(please note I did this from memory after reading the directions on the new stove we had delivered about 2 months ago. That was an LG stove so some differences in the instructions are inevitable.)
Aug 25, 2010 | Sears 61301 Gas Kitchen Range
What space is required behind range to allow for gas hook up
If you follow the installation directions for this range, you should be able to have zero clearance from the wall IF the electric outlet and gas shut off valves are located in the proper places. The gas valve should not protrude more than 2" from the back wall in order to have the stove sit flush against the back wall, when pushed all the way in.
Here's a copy of the installation instructions from Jenn-Air for your stove. Please see page 10 for their recommended location of the electric outlet and gas supply line and shut off valve
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P629-60.pdf
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Gas stove burners will not light on click
Crack the line and see if you are getting gas to the stove first of all. If you are then the pressure regulator is either not set right or bad. Lots of times they do go bad if they sit up a while and no one bothered to cap off the regulator.
Jun 10, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Frigidaire 337 range
regulators are where the gas line coming from the house behind the stove conects to the stove. it's square about 2 inches by 2 inches.
Nov 24, 2008 | Frigidaire FGF378AC Gas Kitchen Range
INSTALLING A GAS STOVE
you would need to get a LICENSED plumber for the installation of gas line. did i mention LICENSED??? its your house dont mess with a guy that tell you he's done some plumbling before
Mar 16, 2008 | Kitchen Ranges
Dryers Logo
Top Dryers Experts
