Question about Soho Lab Wolff Systems Solar Storm 24S 24-lamp Tanning Bed with Face Lamps 24 buld bed with arm and face lamps. Extra long, extra wide tanning surface. 98% Pre-assembled. Proudly made in the USA
How to get acrylic sheets apart from solar storm 24s tanning bed
Need owners manual..can't get apart to clean acrylic sheets and bulbs..need help!!!
How to take apart my sunquest solar pro24 bronze tanning bed to clean it
The Tanning bed must of come with a booklet or
owners manual. Check it out. Or go to the site for the
manufacture.
Tip: As you take the bed apart, take pictures of each step. It will save you time as well as your hair.
Feb 21, 2017 | Health & Beauty
How to replace bulbs in tanning bed
Without the specifics of your bed, I can give you some general info.
  • The first thing you need to do is remove the acrylic. Depending what type of bed you have, this may require a screw driver to remove the metal retaining strip on the outside edge of the acrylic.
  • Set the acrylic aside, & remove the burnt out bulb(s).
  • Depending on the type of bulbs you are using, you may need to place adapters on each end (these can be removed & reused from your old burnt out bulbs).
  • Regardless of bed type, most have one thing in common when it comes to bulb terminals. One end of the bed will have a stationary terminal, & one end will have a springy one.
  • Place one bulb end in the spring side first, press in, & guide the other end into the stationary side.
  • Turn bed on for a test to make sure everything is working properly.
  • Replace acrylic (and retaining strip if necessary), and you're ready to tan :)
Jan 06, 2015 | Health & Beauty
How do you get the glass off to replace bulbs
First, just pop off the colored strip along the entire canopy; mine is a burgundy looking color. This is just pressed into the groove on the flat side that is on the bottom of the strip on the top canopy. You can sometimes get it off with your fingers, but might need to get it started first with a flat head screwdriver. One you start getting it to lift up, the rest pulls off very easily. Then the metal piece on the side will just pop down or up (can't remember which) and then you can remove the curved acrylic by just putting a hand on each side and pulling it out towards you; It is not heavy, but it is big and bulky so it is easier with 2 people but can be done with just one person. I am female and I have removed mine several time by myself. My husband and I just recently replaced all of the bulbs in mine, facial tanner included. Good Luck. It really is easy once you know the tricks. Also, you can download the manual at http://www.docstoc.com/docs/87389135/Sunvision-Pro-24S-Tanning-Manualpdf---WolffTanningBedcom. Sunvision Pro 24S Tanning Manual pdf WolffTanningBed com . Good Luck!!!
Jul 12, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Tanning Bed. I have 6 Balasts on my Solar Storm 24R Tanning bed. I am having difficulty in locating the replacement elctronic balast. They are double balasts operating 4 bulbs each. I can not identify the...
You just need a good electrical wholesaler and they will either have them or get them for you.
Or buy direct from Solar Storm Parts
http://solarstormparts.com/
zip code 71220 Google Search
Jun 20, 2017 | Kitchen Ranges
Soho Lab Wolff Systems Solar Storm 24S 24-lamp Tanning Bed with Face Lamps 24 buld bed with arm and face lamps. Extra long, extra wide tanning surface. 98% Pre-assembled. Proudly made in the USA Logo
29 people viewed this question
Top Soho Lab Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Soho Lab Health and Beauty Expert? Answer questions, earn points and help others
